Go to Post Not gonna lie, I wanna marry the person over at #254 who does their wiring... I have admired it for years. :) - Lightfoot26 [more]
Unread 14-12-2007, 23:08
Re: Mounting of drive system
Originally Posted by M4 Sherman View Post
Dead axle systems are usually lighter then the live axle, and there's less moving parts.
I wouldn't be so quick to say "usually". If live vs. dead is the only difference, then you're probably right. The axle moves in a live system, so that's one more moving part. But the live axle system I'm most familiar with has the axle itself as the gearbox output, saving several parts (sprockets and chains at least). You can just use a live axle in the same sort of application one might use a dead axle, but you get additional design options when you choose a live axle.
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Drive System archiver 2000 6 23-06-2002 22:57
