Go to Post 15 thread derailment points - EmileH [more]
Unread 14-12-2007, 20:48
Re: Mounting of drive system
Originally Posted by maclaren View Post
I think that a dead axle is the only way to go. The reason being is that the torque is moved out from a tiny key to a bolt pattern on the side of the wheel which causes less wear and problems and allows you to remove a lot of weight.
A hex shaft is another option for a live axle. No "tiny" key required.
Unread 14-12-2007, 20:57
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
I'm sorry Im a nub, but does dead-axle have anything to do with using pillow blocks?
Pillow blocks are quite expensive on mcmaster-carr (about 30 bucks a piece)
is live-axle a more economical choice?
and with a live-axle, would you have to connect the sprocket to the shaft?
sorry for the nub questions
Unread 14-12-2007, 21:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The easiest newbie way to do it is to mount the wheel on bearings on a "dead" axle that is just a bolt thru the frame. The sprocket then bolts to the wheel.
Whether or not you need blocks to mount the dead axle, depends on the design of your frame. The kit frame has flanges with holes in them designed for a bolt type dead axle. If you use that extruded stuff then you may need to make blocks or angled plates to mount the axle.
With a live axle, connecting the sprocket you can buy hubs, most teams who use a live axle make most of the parts themselves, it's not really a newbie appropriate thing to try unless you have good help.
here are some of the hubs, the keyed and hex hole type are what you might use
http://andymark.biz/hubs.html
Unread 14-12-2007, 21:09
in between teams
AKA: Luke Van Oort
Nothing really. What I'm talking about is a block of aluminum with a hole drilled partway though (like halfway maybe) so it can hold an aluminum shaft as a dead axle. Then, the block is mounted to the robot with bolts and its height can be adjusted with shims. Not really a pillow block in the traditional sense, but similar.
Generally no. A bolt through a hole in the frame can serve as a dead axle, with live you need keyed/hex/spline/etc shafts, bearings, pillow blocks, so on.
Usually yes. If you used gears for power transmission, you'd connect those to your shaft.
Nothing to be sorry for, everyone was a newbie sometime.
Team 1219: 2009 - Mentor
Unread 14-12-2007, 21:17
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
Dead axle systems are usually lighter then the live axle, and there's less moving parts.
Also, the drop of the middle wheel on a 6wd depends on the type of wheel used.
Unread 14-12-2007, 23:08
I wouldn't be so quick to say "usually". If live vs. dead is the only difference, then you're probably right. The axle moves in a live system, so that's one more moving part. But the live axle system I'm most familiar with has the axle itself as the gearbox output, saving several parts (sprockets and chains at least). You can just use a live axle in the same sort of application one might use a dead axle, but you get additional design options when you choose a live axle.
Unread 15-12-2007, 04:19
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Take a close look at the front view of the module attached to this post.
Unread 15-12-2007, 04:23
AKA: Ari
Also, please take a close look at the 1st picture where it shows the tensioner and how we used shaft collars instead of spacers. It was a lot less hassle when it came to take everything apart.
ID:	5847  Click image for larger version
Unread 15-12-2007, 10:43
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Not only that, it was a good technical question that prompted further discussion. It has been a while since we've had a good live vs dead axel discussion.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 20-12-2007, 16:11
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Last year we used shoulder bolts as axels through the frame, which worked well.
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 20-12-2007, 16:54
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Live and dead axle drivetrain
For the two years we've done 6 wheel (06, 07), Team 190 used both live and dead axles. The center wheels were driven using live axles with a keyed shaft and the end wheels were sprocket and chain driven from the center on dead axles.
Besides the gearing change between the years, the only major difference between the two drivelines was the chain path. In 06, we had a convoluted one to incorporate a system that got taken off the robot before ship, and after almost every match we were retracking a chain. In 07, we had straight chains with simple tensioners and never had any drivetrain problems (until we got to offseason demos and the bearing blocks had worked themselves loose).
The advantage to this system was that it was compact, as the center axle was just the output shaft after a gear reduction, and the outer wheels were just shafts bolted to the frame with wheels on them.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Drive System archiver 2000 6 23-06-2002 22:57
