Go to Post As mentors we need to be good role models for students. Because like it or not, we will be role models. - mathking [more]
Unread 15-12-2007, 08:54
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Re: Plate Thickness
Originally Posted by AndyB View Post
Thanks for the info! Thats perfect. Have you had any complaints about this setup over a conventional aluminum tubing frame?
No, we love the design to death. It's lightweight, easy to design and extremely easy manufacture and maintain.
Originally Posted by Tim Baird View Post
We do the same thing, it's strong. The only difference would be that we use 10-32's for weight savings, and then drill the tap drill all the way through the spacers to hollow out a little more unnecessary meat.
For the areas needing less strength we have also used 10-32's but, with 3/8" spacers
Lexan side panel thickness? Billfred Technical Discussion 10 15-01-2007 13:55
Frame tubing wall thickness sanddrag Technical Discussion 5 03-06-2005 11:04
Fiberglass Thickness archiver 2000 1 23-06-2002 22:53
Thickness of aluminium bars Randy_Ai Technical Discussion 1 04-02-2002 20:09
gear thickness zarb Technical Discussion 10 26-01-2002 22:07
