Go to Post It would be a lot easier if students would quit being so magnificent. Really. - JaneYoung [more]
Unread 14-12-2007, 20:33
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Plate Thickness
Out of curiosity, because I have never tried it on a team, but how thick generally are the plates used on robots like 1902 and 1369's 07's, where metal plating and spacers are used over the traditional aluminum extrusion or tubing.
My guess was 1/8" or 3/16".
http://www.chiefdelphi.com/media/photos/26796
This is plating right? Or is this just another form of Monocoque frame design?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 14-12-2007, 20:43
run the trap!!!
Team Role: Human Player
Re: Plate Thickness
Dunno. But here is a ton of pictures. Looks to be about 1/8".
-Philip J. Fry
Unread 14-12-2007, 20:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Plate Thickness
It's not monocoque design, it's just a frame made from two plates with spacers between them. 1/8" most likely.
Unread 14-12-2007, 23:34
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Re: Plate Thickness
We've been using the same design on 548's robots for the past few years. We use 3/16" plates connected with 1/2" dia spacers with 1/4-20 countersunk bolts with the thread tapped right in the spacer. We refer to the setup as clockwork spacers.
Unread 15-12-2007, 00:18
AndyB's Avatar
AKA: Andy Burchardt
Re: Plate Thickness
Thanks for the info! Thats perfect. Have you had any complaints about this setup over a conventional aluminum tubing frame?
Unread 15-12-2007, 01:39
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
Re: Plate Thickness
We do the same thing, it's strong. The only difference would be that we use 10-32's for weight savings, and then drill the tap drill all the way through the spacers to hollow out a little more unnecessary meat.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 15-12-2007, 08:54
FRC #0548
Re: Plate Thickness
No, we love the design to death. It's lightweight, easy to design and extremely easy manufacture and maintain.
For the areas needing less strength we have also used 10-32's but, with 3/8" spacers
Lexan side panel thickness? Billfred Technical Discussion 10 15-01-2007 13:55
Frame tubing wall thickness sanddrag Technical Discussion 5 03-06-2005 11:04
Fiberglass Thickness archiver 2000 1 23-06-2002 22:53
Thickness of aluminium bars Randy_Ai Technical Discussion 1 04-02-2002 20:09
gear thickness zarb Technical Discussion 10 26-01-2002 22:07
