Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 15-12-2007, 10:43
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Mounting of drive system
Originally Posted by lukevanoort View Post
Nothing to be sorry for, everyone was a newbie sometime.
Not only that, it was a good technical question that prompted further discussion. It has been a while since we've had a good live vs dead axel discussion.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 20-12-2007, 16:11
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Last year we used shoulder bolts as axels through the frame, which worked well.
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 20-12-2007, 16:54
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Live and dead axle drivetrain
For the two years we've done 6 wheel (06, 07), Team 190 used both live and dead axles. The center wheels were driven using live axles with a keyed shaft and the end wheels were sprocket and chain driven from the center on dead axles.
Besides the gearing change between the years, the only major difference between the two drivelines was the chain path. In 06, we had a convoluted one to incorporate a system that got taken off the robot before ship, and after almost every match we were retracking a chain. In 07, we had straight chains with simple tensioners and never had any drivetrain problems (until we got to offseason demos and the bearing blocks had worked themselves loose).
The advantage to this system was that it was compact, as the center axle was just the output shaft after a gear reduction, and the outer wheels were just shafts bolted to the frame with wheels on them.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Drive System archiver 2000 6 23-06-2002 22:57
