Go to Post What? No Poof balls as pillows? Phfff. Amateur. :p - artdutra04 [more]
Unread 15-12-2007, 11:27
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: [FTC]: [FTC]: HELP! Multiple fields set up!!!
Originally Posted by galewind View Post
I'm not sure this is the place for this post, but I'm in an absolute pickle. we're hosting an FTC scrimmage in our school tomorrow, and we have multiple fields. An individual field will work fine, but when I try to put a second field in, my USB to UART (CP210X) controller bombs out and neither device works.
Take a look in the device manager (Control Panel->System->Hardware->Device Manager, under "Ports") and make sure you see two instances of "Silicon Labs CP210x..." there. If you only see one, then unplug one of the field controllers and look at which COM port is listed for the controller which is still plugged in. After that, unplug that controller and plug in the other one and look at which COM port is shown. If they're the same, then that is the cause of the problem. Some of the field controllers at one point were shipped with identical serial numbers which means that Windows has no way of telling them apart when they're both plugged in.
Originally Posted by 1885.Blake
It sounds like you are trying to control both fields from a single computer. I have no idea if that is possible or desirable.
It is definitely possible and has been done at many events.
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
[FTC]: Turnaround time on Official FTC forum ManicMechanic FIRST Tech Challenge 2 09-12-2007 21:14
[FTC]: FTC/VEC First Practice Video Brandon Martus FIRST Tech Challenge 0 28-09-2007 09:47
[FTC]: Hey FTC teams, Vex and a chance to be on MTV? Rich Kressly FIRST Tech Challenge 1 12-09-2007 13:35
[FTC]: What could replace Vex in FTC? Billfred FIRST Tech Challenge 15 16-08-2007 10:16
