Go to Post Yes, I'll admit it...I had a crush on Ken Leung when we all went out together for the college night in 2002. - Elgin Clock [more]
Unread 15-12-2007, 17:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: RPM's
Originally Posted by neoshaakti View Post
How many rpm's is manageable for an FRC robot? And also, does anyone know the speed reduction in a 2007 KOP transmission box.
Basically I'm trying to figure out whether a KOP transmission box is provides sufficient speed reduction... And sorry for the multiple questions, but is it possible to mount a wheel directly to a globe motor? (specs)
or are globe motors more for arms and lifters?
thank you!
In general the KOP transmission does not provide enough reduction to directly drive your wheels without an additional chain-sprocket reduction.
However, there are sprockets provided in the kit (2007) for this purpose, which will give you enough of a reduction to drive at a reasonable speed.
You could mount a wheel directly to the globe motor, but it is not a good idea for two reasons.
Reason one: Globe motors are more for arms and mechanisms like you said, rather than drive motors. They rotate at about 90 rpm, iirc, which is very very slow for a drive system. In addition, they need to be geared down further to provide any sort of torque.
Reason two: Globe motors are notoriously bad at handling side loads. Mounting a wheel directly to the output shaft is asking for trouble, as eventually the motor will go bad.
In general, the drive motors in the KOP consist of the 2 small CIM's, the 2 large CIM's, and the 2 Fisher Price motors. You'd have much better luck using any of these.
Originally Posted by AndyB View Post
Depends on the wheel size. The KOP Transmissions have gear reduction of 12:1 and kind of set the standard for speed reduction. I believe on a 6" wheel with the KOP transmission (which has an output RPM of 292.5 with small CIM motor), it would give you around 7-8 FPS.
I don't believe this is correct. Assuming it has a 12:1 reduction, it outputs ~442 rpm which works out to 11.6 ft/s with a 6" wheel.
2001-2004: Team 100
2006-Present: Team 254
RPM's Mike o. Technical Discussion 1 30-01-2002 18:48
