Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 15-12-2007, 17:03
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
RPM's
How many rpm's is manageable for an FRC robot? And also, does anyone know the speed reduction in a 2007 KOP transmission box.
Basically I'm trying to figure out whether a KOP transmission box is provides sufficient speed reduction... And sorry for the multiple questions, but is it possible to mount a wheel directly to a globe motor? (specs)
or are globe motors more for arms and lifters?
thank you!
Unread 15-12-2007, 17:10
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: RPM's
Math error: see post below.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 15-12-2007, 17:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: RPM's
thank you!
In general the KOP transmission does not provide enough reduction to directly drive your wheels without an additional chain-sprocket reduction.
However, there are sprockets provided in the kit (2007) for this purpose, which will give you enough of a reduction to drive at a reasonable speed.
You could mount a wheel directly to the globe motor, but it is not a good idea for two reasons.
Reason one: Globe motors are more for arms and mechanisms like you said, rather than drive motors. They rotate at about 90 rpm, iirc, which is very very slow for a drive system. In addition, they need to be geared down further to provide any sort of torque.
Reason two: Globe motors are notoriously bad at handling side loads. Mounting a wheel directly to the output shaft is asking for trouble, as eventually the motor will go bad.
In general, the drive motors in the KOP consist of the 2 small CIM's, the 2 large CIM's, and the 2 Fisher Price motors. You'd have much better luck using any of these.
Originally Posted by AndyB View Post
Depends on the wheel size. The KOP Transmissions have gear reduction of 12:1 and kind of set the standard for speed reduction. I believe on a 6" wheel with the KOP transmission (which has an output RPM of 292.5 with small CIM motor), it would give you around 7-8 FPS.
I don't believe this is correct. Assuming it has a 12:1 reduction, it outputs ~442 rpm which works out to 11.6 ft/s with a 6" wheel.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-12-2007, 17:14
Re: RPM's
It has been done. 330's 2002 robot used them to drive a mini-robot for extra points. However, that was maybe 4lbs of metal and wheels. More than that I wouldn't do. (We also used them on an arm in 2004--we used two of them for that particular arm.)
Unread 15-12-2007, 17:27
AndyB's Avatar
AKA: Andy Burchardt
Re: RPM's
CIM Motor RPM = 5310
Reduction = 12:1
Reduced RPM = 442
How'd i mess that one up...
6 * 3.1415 = 18.849" circumfrence
18.849 * 442 / 60/ 12 = 11.5 Feet Per Second
Wow, must have hit the wrong button somewhere. Thanks Cory.
Unread 15-12-2007, 17:31
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: RPM's
Reduction = 12:1
Reduced RPM = 442
Remember that this calculation is for the CIM's free speed. The motor will never achieve that speed on a robot because of load, so the actual output speed is probably something closer to 45/50% of this.
--Madison--
...down at the Ozdust!
Unread 15-12-2007, 17:35
neoshaakti's Avatar
Re: RPM's
hmmm so according to AndyB, the reduced free RPM's or a 2.5'' CIM motor would be 442 rpm...so how much more reduction would a sprocket provide?
Unread 15-12-2007, 17:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: RPM's
That depends on which sprockets you use, but 2:1 reduction is typical.
Unread 15-12-2007, 19:15
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: RPM's
actually lots of RPMs do the work for our team- our Raider Parent Mentor organization....
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 15-12-2007, 19:34
neoshaakti's Avatar
Re: RPM's
haha very funny Mr. Cokeley
just wanted to let you know that this question is a result of the KOP gear box you lent us...thanks a bunch
Unread 16-12-2007, 12:33
Dick Linn's Avatar
no team (Synergy)
Re: RPM's
Something like this inexpensive digital tach might be useful for measuring and calculating a robot's actual top speed:
http://www.meter-depot.com/tacho.html
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
RPM's Mike o. Technical Discussion 1 30-01-2002 18:48
