Go to Post If an alternate is used, all four teams are equal members of the alliance. (Trophies, trips, bling, book tours, custody of the children etc.) - Btower [more]
Unread 16-12-2007, 19:48
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Faceting an extruded line.
Hi
Is it possible to "fill in" an extruded line segment? I attached my current render, an answer would be much appreciated .
~Setsanto
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 16-12-2007, 21:55
adamrw91 adamrw91 is offline
FRC #0701
adamrw91 is on a distinguished road
Re: Faceting an extruded line.
you could convert it to an editable poly. then select all the edges and cap them and there you go!
Unread 16-12-2007, 23:32
Theflexmaster Theflexmaster is offline
Alumni of 103 Animation Team
FRC #0103 (Cybersonics)
Team Role: Animator
Theflexmaster is an unknown quantity at this point
Either use Cap Holes (Modifier List) or make sure you segment is one complete line, no breaks. Making the line an editable spline could help as well, ummm or just playing with the options in extrude. It's not too hard of a fix
Unread 17-12-2007, 00:19
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
think about what you are doing here. If you cap the holes in that segment you end up with a solid block. So why not be efficiant and use object replacment and use a single solid block?
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 17-12-2007, 21:45
Setsanto's Avatar
Team Role: Animator
Hi, thanks for the replies, just one question. What is object replacement? Sorry, kinda new to 3ds.
~Setsanto
Unread 18-12-2007, 11:06
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
~Setsanto
exactly what it says it means. Replacing an object with a different object only its over a corse of a single frame, so if you do it correctly it will apper semless.
A.K.A Llama
[OCCRA]: extruded aluminum bernieseaholm OCCRA Q&A 1 19-09-2007 21:04
80/20 Extruded Aluminum MTA Gearheads General Forum 8 20-01-2007 19:10
T-Slot extruded aluminum blue_crew Technical Discussion 18 29-01-2006 13:05
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
line tracking line BerserkerSpyke Rules/Strategy 1 18-01-2003 17:10
