Go to Post You can't learn anything without breaking some stuff. - DonRotolo [more]
Unread 17-12-2007, 19:09
evanisthat!'s Avatar
evanisthat! evanisthat! is offline
Captin' Kassof
AKA: Evan Kassof
FRC #1902 (Exploding Bacon)
evanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really nice
Send a message via AIM to evanisthat!
pic: Crab Drive Frame
Unread 17-12-2007, 19:11
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: Crab Drive Frame
The thing I like the most about this frame design is that the motors are in a gear box of some sort. I seemed to of not thought of that in any crab drive frame I made, but it does seem to make things a bit neater looking and closes things off quite nicely.
Nicely done good sir!
ps. how big are the wheels? (diameter and thickness)
Unread 17-12-2007, 19:16
Captin' Kassof
AKA: Evan Kassof
Thanks, the entire design is supposed to be as compact and robust as possible.
The wheels are 4" in diameter and 1.5" thick.
108!!!
2007 Las Vegas Xerox Creativity Award winners!
2007 Las Vegas Quarter Finalists, only alliance to challenge the champs!
2007 UCF Finalists... thanks to 1902, 179, and 386 for the crazy jump in!
2005 UCF regional quarter finalist...
2005 Midwest regional quarter finalist...
2005 UCF Website Winner
2005 Midwest "Delphi Driving Tomorrow's Technology" Award.
2005 Championship Curie Division Champions. (thanks to team 175 and team 33).
Unread 17-12-2007, 19:28
FRC #1360
are you considering adding cross beams for support? (I have never made a bot with that big of a outer frame material before so I don't know if it needs it)
Unread 17-12-2007, 20:03
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Is it really such a good idea to have the drive motors sticking down that low to the ground?
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 17-12-2007, 20:05
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
You might want to invert the tranny assembly and have the motors point up. If you use it for a game with any kind of ramp, the apex might nail the motors as you try to climb.
Aside from that, nice job!
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 17-12-2007, 20:31
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Evan, you are crazy. We need to have a talk.
Unread 17-12-2007, 21:47
Captin' Kassof
AKA: Evan Kassof
I don't think cross beams will be needed, with 6" wide supports on the front and back, I doubt it will bend much. I tried to do an FEA of it to test how much force it would take to bend the frame but my computer crashed.
Low motors shouldn't be a problem, as long as the wires are routed safely, besides they are .666" (interesting number, not by design, but curious nonetheless) off the ground, the angle of the picture is a bit deceiving.
If there are ramps in the competition, the trannys can be inverted, but they stick up pretty high, thats why I have them down.
Arefin, we don't need to talk, you know you love this.
Thanks for the questions!
108!!!
Unread 17-12-2007, 23:05
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Hmm is it a good idea to have 2 gearboxes driving the wheel orientation? Maybe they move at different speeds / distance moved and cause uneven tension on the chains across the two sides..
| jamesyong.net |
FVC2007, FTC2008
Unread 18-12-2007, 00:37
viking1902's Avatar
viking1902 viking1902 is offline
Team Viking/Head Mechanical
AKA: chuckie
FRC #1902 (EXPLODING BACON!!!)
viking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of light
Send a message via AIM to viking1902
I believe that the AM 2-speeds are driving the wheels not controling the rotation of the crab pods. The rotation of the pods looks like it's being handled by two smaller motors. You can see the pulley/sprockets poking out of the frame on the top-left and bottom-right of the frame.
Too much bacon for the pan to handle.
Unread 18-12-2007, 02:37
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I'm concerned with the chain wrap around some of the directional sprockets (esp. what appears to be the motor sprocket). They definitely have less wrap than recommended, by whatever rule of thumb you go by. I'd be worried about chain slip. Also, how do you intend to tension the chains?
Unread 18-12-2007, 04:41
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
He has a "tank crab" set up right now.
EDIT: How do you plan on controlling this. Are you going to use the "tank crab" where you will have two joysticks or one joystick with some really sick programming? The picture is kind of misleading me. If you decide to link one side of your robot to the other via chain than you will save weight if you don't want to do akerman steering. Anyways let me rephrase my question, what exactly will your crab, when it is all said and done, be able to do?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 18-12-2007, 11:35
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
So even, i like the design, i've seen it before
one question;
i can see the reason for having the motors like that is so the side members can be machined the same
why not have the motor sitting in the middle? and as somebody already mentioned, it might be good to have the CIMs sitting above the frame, in case there are ramps in the game.
Unread 18-12-2007, 11:36
zander_108's Avatar
AKA: Zander Guerra
Arefin, stop being a crab-drive-basher.
Unread 19-12-2007, 00:40
Captin' Kassof
AKA: Evan Kassof
The main reason there are 2 motors controlling it is because you cant get a chain to wrap around the transmissions... It is really tight and is worrisome to me. Control hadn't really been thought of, although, my friend Gustavo (software guy on 108) is really good and I am sure he'd love to get it to work with a mouse or something. In my original design, the steering chains cross (like an X) which allows the crabs to be turned tangentially, as well as a standard crab drive. I guess there is no reason not to rerun the chains in that way in this design, other than there would be even less wrap around the steering motors. I guess a tensioning system could effectively add wrap and tensioning at once (once again laziness).
Tensioning in general hasn't really been considered, but I knew it would come up when I posted this, so right before I did, I tried to add slots to some of the holes. But for anyone who has ever used ProE, hitting the re-gen button on a dependent assembly does so with caution, needless to say, the entire thing crashed and I had to close without saving. Alas, some well placed slots and some empty sprockets (like the ones on 118) should solve the problems.
108!!!
pic: Ultimate Vex crab drive 2 cire Extra Discussion 9 01-06-2007 16:46
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: Tredded-Tripedal-Modular-Crab-Drive CD47-Bot Robot Showcase 11 28-04-2004 22:06
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
