Go to Post Stop whining about something that can be fixed by working harder. - artdutra04 [more]
Unread 17-12-2007, 20:55
CraigHickman
Posts: n/a
pic: New wheel CAD
Unread 17-12-2007, 21:02
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: pic: New wheel CAD
I'm sorry, did you say "way too heavy?" How light do you need to make your wheels? Even with a 6wd setup and a 0.5lb wheel, you're only saving 1.5lbs from your drivetrain over what you show here.
I think our wheels were about a pound each last year. Then again, we were concerned about machining time, and not weight. It would have taken twice the time on the lathe/bridgeport to take another 1/4lb out of each wheel... Not worth the effort for us, though YMMV. Good luck with the lighter wheel.
BEN
Unread 17-12-2007, 21:07
run the trap!!!
Team Role: Human Player
You could save even more weight by machining it out of polycarbonate instead of aluminum. It would also save a lot of time since feed-rates could be increased.
-Philip J. Fry
Unread 18-12-2007, 00:05
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
BEN
Our wheels weighed 0.23 lbs last year. granted they're 4" not 6". 1.5 lbs is a pretty significant amount of weight when you really start counting grams so to speak. Whether it's worth the time or not is another story
2001-2004: Team 100
2006-Present: Team 254
Unread 18-12-2007, 11:22
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
That, my friend, is a gorgeous wheel! How many machining ops does this one take, and why did you decide to go with a 5 hole/spoke pattern instead of the standard 6?
I have the feeling I'll be seeing another sexy and competitive robot out of 114 again this year! See you at SVR
Unread 18-12-2007, 17:43
CraigHickman
Posts: n/a
BEN
Weight is everything. 1.5 pounds down low is 1.5 pounds of speed you can put into your scoring mechanism.
This one is a 2 op on the CNC. The rivet holes are all even mainly just for show. We actually just sort of drill them on with a power drill when installing the tread. It saves a lot of machine time, and cost.
The 5 pattern is far more stylish, and lighter. Besides, everyone else does 6 or 4, which is why I usually stick with 3, 5, or 7.
Unread 18-12-2007, 22:13
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Hey...
I tried looking up blue nitrile tread on mcmaster but either got too much or too little, do you have a more technical name or part number for what you mean?
Phil Malone
http://www.GEARSinc.org
Unread 18-12-2007, 22:24
in between teams
AKA: Luke Van Oort
Originally Posted by PhilBot View Post
Hey...
Look on page 1189 of the McMaster online catalog.
Team 1219: 2009 - Mentor
Unread 18-12-2007, 23:16
PhilBot's Avatar
AKA: Phil Malone
Cool, thanks.
BTW how does the nitride compare against standard/gum-rubber in wear and traction?
Phil Malone
Unread 02-01-2008, 20:29
CraigHickman
Posts: n/a
Cool, thanks.
BTW how does the nitrile compare against standard/gum-rubber in wear and traction?
The Blue nitrile wears significantly less than the wedgetop (which I'm assuming you're referring to, right? the Brown stuff with criss crossed waffle-esque treading?), assuming you install it right. The reason ours doesn't wear nearly as much as others is how we attach it: rivets. When the tread is riveted at several points, it can flex and move, rather than immediately wearing as it would were it glued on it's entirety.
pic: DryErase is the new CAD... synth3tk Extra Discussion 16 15-12-2007 23:16
pic: New wheel CAD CraigHickman Extra Discussion 4 08-09-2007 01:29
pic: THINK PINK Roccobot 2k7 New Wheel Gabe Salas Jr. Robot Showcase 7 24-02-2007 13:23
pic: my new wheel design hockeystud91 Extra Discussion 9 20-02-2007 19:18
Mecanum Wheel CAD file or Drawing Leav Technical Discussion 2 17-01-2006 06:35
