Re: pic: 2008 IR Board Model
is this one your version or the version Ben gave you?
Judging from the time this pic was posted versus the time Ben replied in the Hint thread, added to that the factor that this looks like the same version on www.firstcadlibrary.com, I'm assuming it is Ed's. Don't quote me on that.
It's mine. I haven't seen the official version from Ben yet.
So originally I thought gap between the plastic stands on the white block was for supporting 2 connectors, but now I'm told that the gap is for a keyway type feature that a connector would have to line it up correctly with the pins so you don't put it on wrong.
So.. my question to all the EE's in the crowd, or the folks who like to tinker with circuit boards, what kind of connector could it be? |
Oooh.. Molex eh?
![]() I'll have to ask a few of the guys at work who worked there or worked with them through their professional careers about this discovery. (I work at a place where we make cable assemblies, connectors, and antennas. We have a lot of good people from the cable & connector industry workin' with us.) Thanks for the info! |
#7
2) I encourage you to pull up the data sheet online and confirm. 3) KK Friction Locks are used EVERYWHERE. I don't mean to be a wet blanket, but I will be very impressed if that piece of information leads to anything. It tells you about as much as knowing what model of PIC is on the board. |
#8
Oh wells. No harm in trying to decipher just another detail of the board I guess. ![]() |
#9
Bingo! http://delta.octopart.com/Molex__22-23-2061.pdf
This seems to match. Quote:
But, now comes the big question. What's the mystery cable going to that this component is going to be used for? Typically these type of connectors (from what I can gather) are used for power supplies on computers. Possibly we can adapt these with the Ribbon cable provided via a crimping type mate housing: http://www.molex.com/catalog/pdf/MX2695.pdf With this baby on the end of the wires: http://www.molex.com/pdm_docs/sd/008650804_sd.pdf Can't be that hard to do. ![]() Last edited by Elgin Clock : 19-12-2007 at 13:38. |
#10
looks like you nailed what it is!! now what can it be used for is the question of the hour isn't it?
If only I knew.....I'd be able to share it with you all... too bad I don't know Any guesses??? I'm not electrical guy so I'm not so sure about it at all |
#11
Saaaaaaaayyyy....
Isn't that the connector used on the F.L.U.X. Capacitor? ![]() |
#12
The patent on that expired just 2 months ago. Man these guys work fast ![]() |
#13
http://www.tfaw.com/Profile/Back-To-...plica___311677 |
| 2008 Offseason event MARC being moved to JUNE 28, 2008 | Steve Ketron | Off-Season Events | 10 | 21-03-2008 07:55 |
| Model Airplane Propeller Model | SgtMillhouse648 | Inventor | 2 | 20-08-2007 19:08 |
| Lights in Joystick board or control board | rcubes85 | Control System | 15 | 26-02-2005 23:40 |
| pic: Field Model | Pâzinha | Extra Discussion | 3 | 23-01-2005 08:56 |
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
