Go to Post 1. If I had a nickel for every time I heard "But we passed at XXXX regional" I would have retired a long time ago. - Al Skierkiewicz [more]
Unread 18-12-2007, 12:57
kuelin kuelin is offline
FRC #1811
kuelin is an unknown quantity at this point
USB chicklet overheating
has anyone come across this problem?
Unread 18-12-2007, 13:56
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: USB chicklet overheating
no, I can't see how it overheated unless you have it in an enclosed case of some sort
Unread 18-12-2007, 14:32
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
I remember hearing Mike Copioli (designer of the chicklet) talking about this during the season. 99% likely the reason is that you are putting too much power into it. There isn't really any reason why it would overheat otherwise.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 18-12-2007, 15:30
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
It's best to use one of the 7.5 Volt "Back Up" batteries for this.
Ed Sparks
MECH TECH FRC-3959
Unread 18-12-2007, 16:18
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Haven't seen the problem, but given that the Chicklet is an unprotected PCB, one of my thoughts is that you might have a short somewhere. Make sure there's no shavings or anything on the board anywhere, and make sure the board isn't touching any kind of metal. It might help to use an air compressor to blow off the board (small metal dust or shavings can be hard to spot).
Unread 19-12-2007, 00:23
FRC #1811
Talking Re: USB chicklet overheating
wellllll thanks for all the help
ill describe it a little more... its been said here that maybe im putting too much power but doesnt it take 9V to power the board? i have a 9V pack connected to it, 6 AA batteries 1.5 each well yeah
idk if overheating is the best word for it but when i connect the battery pack ill wait a few seconds like about 10 15 and the heat especifically comes from UNDER the header pins.... from nowhere else but there
weird ? lol
USB Chicklet Power Smoking_Gun Control System 5 25-02-2007 02:06
USB Chicklet IC12 whytheheckme Electrical 10 22-02-2007 07:06
USB Chicklet SleeveofWizard Control System 11 28-01-2007 22:45
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Subforum suggestion: USB Chicklet discussion Billfred CD Forum Support 3 17-01-2007 22:56
