Go to Post Sometimes it is worth it to stop and read what you've written before posting. - [more]
Unread 17-12-2007, 22:03
Aren_Hill's Avatar
Build Nifty Things
pic: another iteration
Unread 17-12-2007, 22:06
Aren_Hill's Avatar
Build Nifty Things
Re: pic: another iteration
This is the frame im working on a transmission for (http://www.chiefdelphi.com/forums/sh...ad.php?t=59994)
The transmissions would go on the short ends between the modules vertically and drive the input sprockets seen.
A guy who likes robots.
Unread 18-12-2007, 17:55
Jacob Plicque Jacob Plicque is offline
FRC #0086 (Team Resistance)
Jacob Plicque is an unknown quantity at this point
Aren,
What is the weight of this variation of the crab drive? It looks like it should be lighter than the previous 41# version. We built a single speed creb drive in 2004.
Regards,
Jacob Plicque
Team 86 Mentor
Unread 18-12-2007, 17:59
Aren_Hill's Avatar
Build Nifty Things
I've been a little lazy in regards to setting the properties of all the materials but i know this one will end up alot lighter than the last one, not sure how much.
all the frame tubing is 1x1x1/16 wall
Unread 18-12-2007, 20:32
CraigHickman
Posts: n/a
How wide are your wheels on this?
And what motor are you using to steer the modules?
Unread 18-12-2007, 20:45
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
I'm not entirely sure of the specs he made for this but i believe it is going to be turned by a fisher price through a bane bots gear box. Not sure on the wheels i believe they are 2.25?? possibly
Unread 19-12-2007, 07:50
Aren,
Don't forget some form of bearing surface at the bottom of the module. Between the torque from the wheels and the side load from a pushing opponent working on the moment arm of the entire module, the modules will bend and flex. Although it doesn't seem like much, it can put the wheels on edge which will lose a lot of friction and steering accuracy. If you remember, we have a circular plate on the module with a circular delrin bearing turning inside a fixed mating plate attached to the bottom of the frame. In the past we have used a variety of things, but the delrin ring seems to work the best when we choose to use crab drive.
Unread 19-12-2007, 07:56
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I love all the new crab designs I've been seeint lately! Keep up the good work man! .... But one question, where are the chains/motors? Will you be doing something like a central motor location (the Robonaut's V6 from '07) or will you doing something along the lines of the SigmaC@ts or something different?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 20-12-2007, 01:28
Aren_Hill's Avatar
Build Nifty Things
Al. The bottom disc of the modules will be supported very closely to yours but instead of a full ring it will have 4 tangental squares it will run against most likely.
Pavan. This swerve will have 1 gearbox up front (narrow end) and one on the opposite end. Still giving us the ability to tank drive and spin in place. Similar to your setup but with 2 gearboxes instead of 1.
pic: Another one... Cody Carey Extra Discussion 9 01-03-2007 19:46
pic: Another triple play? Arefin Bari Extra Discussion 10 01-07-2005 07:51
pic: Team 488 Arm Prototype -- Iteration 4 Madison Extra Discussion 1 13-02-2005 01:54
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
121, another competition, another victory. Greg Perkins Off-Season Events 27 06-06-2002 23:13
