Go to Post While you look at it as punishment, I look at it as a challenge. - Daniel_LaFleur [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 18-12-2007, 22:20
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
Unhappy Downgrading Vista to Xp
Last september i got a laptop with vista home premium installed the model number is HP Pavilion dv9233cl Notebook PC i know i should dl the drivers i plan on dling the to a partition. but there are a few things that im afraid of...
1) if i do reformat although ive had done before (today was my thrird time reformating my laptop) but reformatting to Xp will my partitions be affected.
2) am i to buy an xp program?
basically i just want somone to guide me through step by step i dont want to mess it up. also after the reformat and the installation of the drivers
please help vistas annoying me so much
-Jeff
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Unread 18-12-2007, 22:27
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Downgrading Vista to Xp
personally i dont see why you want to do this but i bet there's a help file on the microsoft website
Unread 18-12-2007, 22:29
DonRotolo's Avatar
Back to humble
FRC #0832
First of all, you will need a copy of Windows XP and an appropriate license. Not only will it not work without it, nobody here condones "bypassing" any legal issues...
You won't need to partition your HDD as long as there's a partition available for XP to live in. If you want to get rid of Vista completely, just format the HDD, put in the XP CD and boot from it (the BIOS may need a tweak to allow this). The CD will walk you through the install, about 40 minutes typical.
One thing to be careful of: Vista supports certain hardware, but XP supports less. If XP does not support your hardware, you'll have problems. I recommend a phone call (or web site vsiit) to HP to ask about that.
Don
Unread 18-12-2007, 23:18
Bharat Nain's Avatar
Since two threads are created, maybe a moderator can merge this into the other thread. For now all discussion can go here.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Inventor on Vista? popo308 Inventor 9 03-08-2007 00:33
Vista Upgrade Problem SgtMillhouse648 Chit-Chat 15 15-05-2007 09:37
Vista compatibility? EHaskins Programming 29 19-03-2007 11:22
Windows Vista ThomasP Chit-Chat 15 01-02-2007 07:16
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
