Go to Post Our coolant system consists of a freshman with a squirt bottle. - Holtzman [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 18-12-2007, 23:02
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Downgrading vista to xp
vista has a built in function that compares to acronis imaging in the way that it periodically takes an image of you hard drive and stores it in the second partition. XP doesn't do that, it keeps the back-up files on the same partition, which if you think about it is not good because if your disk blows your lost and theres no way of switching it to a different partition for saving. As for the second partition its basically a copy of windows xp that is set as the secondary boot partition if the first doesn't boot. The second partition kicks up and runs windows recovery, which usually slows down the machine and doesn't work as well as a full re-install.
Championship - Delphi "Driving Tomorrows Technology"
Downgrading Vista to Xp Tri_Lam Math and Science 3 18-12-2007 23:18
Inventor on Vista? popo308 Inventor 9 03-08-2007 00:33
Vista compatibility? EHaskins Programming 29 19-03-2007 11:22
Windows Vista ThomasP Chit-Chat 15 01-02-2007 07:16
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
