Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Thread Tools Rating: Thread Rating: 25 votes, 4.84 average. Display Modes
Unread 19-12-2007, 01:42
Turtlecoach Turtlecoach is offline
2007 NASA/VCU Champions
FRC #2108 (Awkward Turtles)
Turtlecoach has a spectacular aura aboutTurtlecoach has a spectacular aura aboutTurtlecoach has a spectacular aura about
Re: pic: Game hint
This has been an impressive thread with all the speculation as to how this IR board will be used. Here is my two cents. Think about what FIRST has always done...they want the teams to develop solutions to problems. NASA eventually wants to put up bases on the Moon & Mars. You need robots working together to make that happen. I bet that the KOP will contain an IR transmitter that will mount on the robot along with this receiver. Robots on the field are going to have to work together to accomplish a task such as a coordinated lift. Four outputs - UP, DOWN, FORWARD, BACK come to mind. The instructions for setting up with a TV remote are so you can test the bot before competition. The white plug would be for regional programming when you bring the robot up for inspection so everyone has the same "learned" program. The LED's on the board would be for diagnostics when checking the bot out during the build and confirming the programming at the regionals. Most likely wrong, but its a thought.
pic: 2007 Game Hint? dlavery FRC Game Design 161 07-01-2007 13:42
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
Offical Game Hint! Greg Needel Rumor Mill 117 21-12-2006 16:25
dlavery game hint nuggetsyl Rumor Mill 173 20-12-2006 22:00
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
