Originally Posted by Kevin Sevcik
DeepWater,
It's entirely likely you've gotten a bad board, but have you checked the voltage out of the voltage regulator while the board has power? If you measure across C4 with negative on the pad closest to the ribbon cable, you should get 5V. You could measure across pins 2 and 3 of the big whit connector with negative on 3 to check as well. Beyond that, I'm not sure what it could be.
Good idea Kevin! The board is up at the shop tonight but I will check the 5V output ASAP tomorrow.
