Go to Post My fondest memory was asking questions about Spirit and Opportunity to a NASA scientist while dressed up in a lion suit. - Adam Y. [more]
Unread 19-12-2007, 13:15
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
IR Sensor with Bot?
Has anyone tried connecting the IR sensor to their 2007 bot?? if someone has can you explain how or what it did??
What sort of things can you do with the sensor attacted?
Unread 20-12-2007, 00:29
Steven_585's Avatar
Steven_585 Steven_585 is offline
Webmaster, Programist, Mediographer
AKA: Steven Pestana
FRC #0585 (Cyber Penguins)
Team Role: Webmaster
Steven_585 is an unknown quantity at this point
Re: IR Sensor with Bot?
No, but i am excited to see what we are going to use it for!
I know why you're here. I know what you've been doing... why you hardly sleep, why you live alone, and why night after night, you sit by your computer. I know because I was once looking for the same thing. It's the question that drives us. It's the question that brought you here. You know the question, just as I did.
Unread 20-12-2007, 00:40
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
haven't yet, but I would assume you are supposed to wire the outputs the white wire of an old PWM cable, and program/plug it in as a sensor.
But, don't take my word for it.
Unread 20-12-2007, 00:57
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This is only speculation, but it would make the most sense as a way to interact with either the field or the other robots on the field.
They could use it as an analog to the light, so you'd be able to tell whether a robot is on the same alliance or not. The extra connector might be for a transmitter board.
The other option, and probably more likely, is to revisit the IR beacons from a few years ago in a more user friendly way. The connector may provide more IR inputs besides the default one on the board.
On a robot now you can use it to triangulate your position based on two beacons by sweeping it back and forth and tracking the angles where you see the beacons.
Unread 28-12-2007, 07:21
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
One of our engineers connected the IR board to a Vex robot. He can control the bot with his DVD remote
It goes forward, stops, rotates left and right using the arrow keys on the remote.
I found this information on the PIC16LF87 chip on the IR board: http://www.tauntek.com/IRMimic-chip-datasheet.pdf
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 29-12-2007, 00:17
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Our team did the same last weekend
http://www.chiefdelphi.com/media/photos/29439
http://www.youtube.com/watch?v=XUx2w3J_jDk
It's great to see that this sensor is so easy to use right out of the package, and the range seems to be pretty good. Ours worked from about 50' away, but that's only when the receiver had line of site with our remote.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Last edited by Richard McClellan : 29-12-2007 at 00:19. Reason: added last paragraph
Unread 29-12-2007, 12:29
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
Exclamation Re: IR Sensor with Bot?
Our Team has successfully programmed and worked the IR with our robot, we tried basic programming like just two controls up and down and were successful in manipulating the robot to move its flipper arms up and down
Unread 30-12-2007, 19:02
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
1625 had there IR board connected to an RC and it was working until some lose wire ends bumps some terminals they were not supposed to touch. (and now we don't have a board that works)
Unread 30-12-2007, 20:43
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
After setting four buttons into the board's memory, we connected each output-signal wire to it's own white wire to a PWM wire. The black wire, on the pwm wire, should connect the the ground (common) that you used to power the IR board, and the red wire can be left unconnected.
You can connect the PWM wire to any of the digital I/o's. We used 1 - 4, and used the remote to control our flipper.
Just be sure to program it right.. since it's a 100msec 5v+ signal, and the processor loops every 26.2 msecs, you're gonna get a digital value 3 times in one push of a button. Basically, if you're using something that needs to flip-flop between two states, it'll go from 0-1-0 in a push of a button.
ahhh Division Finalists!!
Unread 12-01-2008, 14:49
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Could you draw a picture or a little instructions for those of us who are a little illiterate in the ways of wiring.............Please
Please help me with this sensor Ianuser Programming 7 12-02-2007 00:44
Help with Gear Tooth Sensor RedOctober Electrical 3 27-01-2006 18:38
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
Need help with Sensor Hop_of_752 Programming 5 06-02-2004 23:43
A bot with no name... Kris Verdeyen Robot Showcase 23 11-04-2002 13:52
