Go to Post NERDs...gotta collect them all! - Conor Ryan [more]
Unread 20-12-2007, 10:11
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Can't install Inventor 2008
The company I work for has allowed us to use their computer lab for our FIRST Robotics team.
However I and our IT technician can't get Inventor 2008 or 3ds Max 2008 to install. We keep running into tis message, even though we have full Admin rights:
"This installation is forbidden by system policy. Contact system administrator. C:\MaxInstall\support\msxml\msxml6.msi"
We have brand new HP computers running Windows XP Professional.
Just as an experiment I tried installing 3ds Max 9 (last year's version) and it worked fine.
Has anyone else had this problem with Inventor 2008, and found a work-around?
Unread 20-12-2007, 11:02
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Can't install Inventor 2008
Although what you describe sounds different, you may want to try uninstalling Adobe Flash Player - I know with older versions this would cause problems about 80% the way through install.
Unread 20-12-2007, 15:38
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
This sounds like the same problem you posted about in this thread. Did you investigate whether the problem is the same one as the last two posts in that thread described? Does Raul's solution fix the problem?
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 20-12-2007, 15:56
AKA: Kevin Thorp
I PM'd Raul. No reply yet.
Unread 20-12-2007, 15:58
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
you are trying to install it on a server??
Unread 20-12-2007, 15:59
AKA: Kevin Thorp
Nope. Individual stations.
Unread 20-12-2007, 16:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Call Autodesk?
Unread 20-12-2007, 16:03
popo308's Avatar
AKA: Brent
are you installing it on the windows drive on the pc??
(C:\\ or D:\\) whatever your windows is on??
(or is it a singular HD?
Unread 20-12-2007, 17:47
AKA: Kevin Thorp
Sanddrag: Unfortunately Autodesk doesn't offer phone support to FIRST Robotics teams. They do have email support but the response is a little sluggish.
Popo308: I'm trying to install it on the default location - the same C: drive windows is on.
Unread 21-12-2007, 16:17
popo308's Avatar
AKA: Brent
ok if you can try to install it on a external or network drive somewhere other than your C:\\ drive. that worked for me when i had that problem
Unread 08-01-2008, 01:35
frenzied frenzied is offline
frenzied is an unknown quantity at this point
I had the same issue but with Autocad 2008.
The solution I found was getting the XML6 SP1 version from microsoft's download site (http://www.microsoft.com/downloads/d...isplaylang=en). I then replaced the msxml6.msi file with the one I download (it has to be renamed from msxml6_x86.msi to msxml6.msi). Ran the install and it worked fine.
P.S. I signed up just to post this for future reference for other people.
Unread 08-01-2008, 14:12
tekrrr tekrrr is offline
FRC #1294
tekrrr is an unknown quantity at this point
A simpler method is to make sure that MSXML 6 is installed under Add/Remove programs. It is probably already installed and that is causing the problem. Otherwise install it from Microsoft's website. It is free.
Then in the directory where you have all the install files, find setup32.ini. Make a backup copy of this just in case.
Then edit the original using notepad. Use find to locate the [MSXML] section.
Insert a semicolon at the beginning of the two entries showing the EXE locations. This makes them comments and they will be ignored. Save the file and exit.
Rerun setup.exe and it should work. It did for me.
Inventor 2008 Jeff 801 Inventor 28 14-12-2007 18:25
Can't Install Max 2008 Kevin Thorp 3D Animation and Competition 5 08-12-2007 17:35
Inventor 2008 files in Inventor 11 pufame CAD 1 18-09-2007 19:19
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
Urgent problem, probably with Inventor 11 install. Eric Scheuing Inventor 4 03-01-2007 07:43
