Go to Post That sound you hear is a student on the mechanical team trying to get out of the shipping crate you closed too early. - Al Skierkiewicz [more]
Unread 20-12-2007, 10:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Problems with IR Board
Originally Posted by keen101 View Post
I was using a 7.2v back-up battery.
Doesn't seem very likely that that would fry it.
Not from overvoltage, at least!
Thanks for the reply....I wonder what's going on....
Unread 20-12-2007, 10:41
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
my thoughts IT'S PART OF THE HINT!!!!!! Quick somebody find something out on 5v regulators!!! ()
In all seriousiness though We are going to try this
Unread 20-12-2007, 11:03
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Yes, it does seem strange that almost everyone who has a problem with the board is an issue with the 5v regulator.
Perhaps a design flaw. I shall e-mail someone from FIRST teams, to take a look at this page.
...as for options... I say try and fix it. Mostly because It could be cheaper than shipping it off to FIRST to get fixed. and also because I have no idea where you can get a new one at this time. Maybe try e-mailing IFIROBOTICS.com. Besides, you'll probably have access to order a new one from ifirobotics later.
We used something like a L809h. Maybe not a perfect match, but it fixed the board, so I'm not complaining. So, you should probably try and get an L805, otherwise improvise.
Usually I would not recommend trying to fix electronics from FIRST (ie. camera board), but in this case... I have no idea if there any kind of warranty that could be void. I would assume there is no warranty. That's the problem with releasing cool electronics as a game hint. You virtually have no knowledge about the device.
Unread 20-12-2007, 11:10
IFI isn't in the production or supply loop on this IR board yet.
For technical assistance I'd talk to Ben Wrightsman at Diversified Systems Inc. the manufacturers of the board.
For a replacement we'll probably have to go through FIRST.
I have a message in to FIRST and will let you know what I discover.
So far the reported failures are quite small in regards to the 1500+ boards produced, so I'm hopeful it's a less than 1% failure rate. Ben told me they sampled boards coming off the production line and the samples all passed, but not every board was tested due to the time constraints of the Christmas rush.
P.S. Based on keen101's experience it does sound as though teams should run these for some time to make sure they catch any marginal failures early.
Unread 20-12-2007, 11:06
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
EDIT: Disregard the next paragraph...
I'm thinking this might be an oversight in the circuit design. The 78L05 series of regulators are rated for 100mA max output current. And the IR manual claims the circuit draws 100mA when an LED is on. Granted, that's a transient draw and the things are rated for occasional current peaks above that, but if it's been derated from overheating during the soldering process, then it could be marginal.
Of course, something could have just been shorted while you were testing it or something. At any rate, you should be able to find a 78L05 regulator of some brand at a local electronics shop that actualy carries things like resistors and caps and such. If you can find a 7805 or 78M05 regulator in a TO-220 package it'd probably be hardier, but you'd have to really try to jam it in to the same footprint, and heaven knows if any of this will be legal come kickoff.
EDIT: Whoops! I must have misread the IR manual, current draw is certainly not close to 100mA....
Unread 20-12-2007, 11:19
keen101's Avatar
Ubuntu Linux User
as far as how mine died... It shall probably always be a mystery.
Maybe something shorted, but I think overheating is more likely. I had been playing with it for over an hour. Enough time to overheat?
Besides... I didn't think anything could short out on an anti-static bag. Who knows, maybe my finger slipped and shorted something. seems dubious though.
Unread 20-12-2007, 11:36
MrForbes's Avatar
AKA: Jim
beeing over 40, I had to take a picture of the part to be able to read the writing on it!
Unread 20-12-2007, 18:56
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Looking at your picture, the part is made by National Semiconductor (thats the funky looking 'N' as the first letter) .
A quick search found a data sheet here ( http://www.national.com/ds/LM/LM78L05.pdf )
While they are ESD sensitive devices, they tend to be rather robust so a little handling should not hurt them very much.
There are a number of things that these little guys dont like:
1: Input power and ground reversed. So watch your polarity when applying power.
2: Voltage on the output being driven higher than the input voltage. This typically only happends with some sort of inductive kick, but ...
3: Applying more than 35 Volts at the input. Some power supplies (especially older ones) may spike when turning on. Check your power supply with an o'scope to see if it spikes (DMMs don't read fast enough).
They can be bought here http://search.digikey.com/scripts/Dk...M78L05ACZNS-ND
___________________
- Tennyson, Ulysses
Unread 20-12-2007, 22:33
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Hmmm.....
Says in the data sheet that these regulators have short circuit and thermal protection built in. In other words, given that the power source is within spec, you should not be able to destroy them (no matter what the load). Maybe some were accidently powered up with reverse polarity at some point. I'm leaning toward the explanations in Daniel's list.
Ed Sparks
MECH TECH FRC-3959
Unread 20-12-2007, 22:46
GaryVoshol's Avatar
Cogito ergo arbitro
If anyone is going to modify/fix this board, wouldn't the work have to be done AFTER kickoff?
(since 2004)
Unread 20-12-2007, 23:38
nautica's Avatar
nautica nautica is offline
nautica is an unknown quantity at this point
Our team successfully trained the chip today.
All we did was follow the instructions about pressing the buttons.
We were able to light up the LEDs using channel buttons (1-4) on a universal TV remote.
Tally so far:
358: LEDs flash during learning. After, either error light or nothing
456: Totally dead, 78L05 has no output
846: LEDs flash during learning and afterwards when controlled by remote.
1357: Worked, then 78L05 fried. Maybe anti-static bag?
2144: Board works, LEDs do not light
2199: Error LED lights sometimes, not "0" (learn loop) LED
Unread 21-12-2007, 01:36
keen101's Avatar
Ubuntu Linux User
Heh. Maybe people should start using the numbers that Don supplied as error numbers.
for example: I had a "1357 error" on Wed.
Tally so far:
Then again... maybe not. I don't know if it would help or not.
Unread 21-12-2007, 06:43
Please focus this thread on issues with the board only.
Can be failures, potential ways to kill the board, or just interesting unreported behavior, such as, getting the LEDs into a chase sequence.
Let's assume most of the boards operate normally, and we're looking for that 1%.
I added a thread with a poll where we can report that our boards are working great!
Please don't repeat the talley if you haven't added your team to it. Otherwise it just takes up space.
We're looking for added value.
I'd like to avoid a 1500 post chatty thread of who's board works.
Unread 22-12-2007, 14:24
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Ed Sparks View Post
Hmmm.....
Thanks.
The short circuit protection in this chip is a current limiter circuit. That said, the chip wont survive prolonged usage at max current (>140mA).
The Thermal protection is also a short term stopgap measure. The output current is driven by a FET which as it heats up provides lower current. This will slow down the heating process but will still fail if the chip is allowed to continously run at high current.
I've never really had issues with a National Semiconductor chip. They tend to be much more robust that some of the other knock off chips. Makes me wonder if something else on the board is drawing too much current.
___________________
- Tennyson, Ulysses
Unread 22-12-2007, 15:07
keen101's Avatar
Ubuntu Linux User
Is this going to be a problem when running off our robots on 12 v batteries, and probably at max current for long periods of time?
Will one of those auto-resetting breaker fuses protect this?
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
problems with G22 JMH Electrical 2 19-01-2005 20:52
Problems with referees?! LauraN General Forum 16 22-03-2004 17:05
School Board Problems Matthew_H General Forum 47 16-03-2004 18:32
