Go to Post Sometimes, it's all about the people. - nixiebunny [more]
View Poll Results: What version control tool(s) do you use?
SVN 22 61.11%
CVS 6 16.67%
VSS 0 0%
Other please post 5 13.89%
None 3 8.33%
Voters: 36. You may not vote on this poll
Unread 29-11-2007, 14:47
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I've been using SVN for some time, but I'm starting to have issues. I have been using TortiseSVN, which is a great tool, connected to a file system repository on a network share or external drive or some type. This is an acceptable system for small projects, but when I need to be able to colaborate with others it is often nessisary to have a secure repository on the internet. I host several websites already, all running on IIS7, so most of the hosting issues should have been solved, but no.
SVN is only compatible with Apache and IIS and apache don't play well together, so if I want an SVN server then I would need to either migrate all of my existing websites to Apache or, run the SVN server on another machine. Neither of these options are practical.
I also can't afford to pay for SVN hosting by someone else.
So, finally to my question. I'm looking for alternitives to SVN, or at least a way to host it.
What version control tool(s) do you use, if any, and you do use one does it work when IIS is installed, or even on Windows?
Thanks,
Eric
Eric Haskins KC9JVH
Unread 29-11-2007, 16:23
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: What version control tool(s) do you use?
At work I use Perforce. It's got a standalone server and its own client, both of which can run on both Windows and Linux. It's a great system; unfortunately, it's proprietary, and you can't use it for more than two clients without a license (open-source organizations can get licenses for free), so I don't suppose it would suit your purposes.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 29-11-2007, 17:05
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
we use a googlecode (svn) account because it's free and takes minutes to set up vikingrobotics.googlecode.com
also I use tortoise svn as a client program
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 29-11-2007, 17:28
Phil Mack Phil Mack is offline
FRC #0836 (RoboBees)
Phil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to behold
836 uses CVSNT on Windows XP with tortoisecvs for shell integration.
~Phil
Unread 29-11-2007, 18:09
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
...except by doing so you've violated Kevin Watson's license.
First, you are licensing your code under the GPL, but you cannot do that because Kevin's code (which you use) is not compatible with that.
Second, everything on Google Code is public, which means you are going directly against his request:
Originally Posted by Kevin Watson
Please do not make copies of this source code, modified or un-modified, publicly available on the internet or elsewhere without permission. Thanks.
That comment is in this file:
http://vikingrobotics.googlecode.com...amera/camera.c
If you have requested permission from Kevin to do this and he granted it, then my apologies. I'd be surprised if he agreed to relicense his code under the GPL to you though.
Unread 29-11-2007, 20:03
AKA: Brian Barrett
FRC #2331
hmmm forgot about that ill take kevins work down
Unread 30-11-2007, 10:53
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Google Code is sweet, I encourage people to try hosting their Technical Manuals and Resources for FIRST Teams on Google's service, the project doesn't have to be just code. You can see the latest revisions and get updates when any new documents are created.
http://code.google.com/hosting/createProject
(fore warning, you might want to learn about different licenses)
http://en.wikipedia.org/wiki/Free_software_license
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-12-2007, 20:56
Catherine Sea Catherine Sea is offline
Junior Member
Rookie Year: 1995
Catherine Sea is an unknown quantity at this point
I recommend SourceAnywhere Hosted for you. It is a SQL-based source control tool delivered as a SaaS application and it provides all of the key features of VSS, plus much more. And now it's free hosting for 3 users.
It also has Standalone Edition.
Thanks.
Catherine Sea
Unread 17-12-2007, 09:28
dmatsumoto dmatsumoto is offline
no team (Robot Stew)
dmatsumoto is an unknown quantity at this point
The school I coach at doesn't use version control yet, but I was going to suggest Subversion for their FLL and FTC teams because I am familiar with it (we use it at work). If you can't run SVN on a separate server, have you tried VMWare Server (which is free) to host SVN on a virtual server?
Unread 17-12-2007, 13:29
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
I would suggest using google code if you are just starting with subversion. They the setup is painless and they supply good documentation. They also have a large userbase full of people willing to help you with problems.
code.google.com
Unread 20-12-2007, 12:32
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
If you host your code on google, you should be sure to only host the code you write since I think Kevin Watson's code asks to not be distributed anywhere else.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Unread 20-12-2007, 13:15
AKA: Eric Haskins
That has already been addressed in this thread, and that is one of the reasons I don't use google code.
Eric Haskins KC9JVH
Unread 20-12-2007, 17:35
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
We use git. We have a server at one of our homes that commits get uploaded to. Actually, it broke after some tinkering. But given our small programming team, we don't work on different computers (and when we do, sneakernet works fine).
There isn't any (as far as I know) GUI for it on windows. But the programming laptop has cygwin with git installed.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 20-12-2007, 19:00
AKA: Eric Haskins
I hadn't heard of Git before. It looks interresting, but if I want a Linux based soluition I would just run SVN.
I've just discovered another issue with running most of this soluitions mentioned in this thread. Appearently our school has locked all ports, except 80, so we can't even use any of the existing tools I know of.
Eric Haskins KC9JVH
Unread 21-12-2007, 11:37
I wouldn't say it is Linux based, it was just made by Linus, and the tools haven't been ported (besides cygwin and msysgit).
We had a problem with only having ports 80/443 and CAD. We wanted a centralized CAD server that we could access from wherever, but that didn't pan out (so we set up a small network of our CAD computers when we work on that.) Apache has an SVN thing, which works on port 80, but I'm not sure about its limitations. I like Git because it doesn't have to be centralized. Just go into a directory, `git --init`, and you're set. If you do make it centralized so you don't have to do it sneakernet, you can have a cool web interface like this: http://repo.or.cz/ . Can't show you ours, because of Kevin's code. *shrugs*
What programming tool does your team use? ham90mack Programming 15 13-10-2007 15:52
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
What view do you use? Brandon Martus CD Forum Support 10 02-12-2003 17:32
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
