Go to Post This place is much brighter than most institutions I have seen. It also seems to be lacking straight jackets which I think is a mistake for many of us. - Andrew Schreiber [more]
Unread 20-12-2007, 14:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What is the best place to mount CIM motors...?
If you mount the transmission between two wheels, and drive those wheels with separate chains, then drive the furthest wheel with another chain off the center wheel, then chain failure would not be quite so much of a problem. Of course building a reliable chain drive system in the first place is a better idea
What you end up doing will probably depend on your design and fabrication skills, abilities, and equipment. It's really easy to set an Andy Mark shifter trans on top of the frame between wheels and run chains from there to sprockets on wheels that are mounted on dead axles, no fancy machining required.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Where to get the CIM motors? PlasmicDragon Motors 5 22-01-2007 14:03
2 CIM motor mount 56 mm banebox... brennerator Inventor 2 19-01-2007 07:57
Large CIM Motors - Removing the sprocket PuiChi Motors 5 13-01-2006 16:01
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
