Go to Post And, just for the record, dlavery is on my mental ignore list from September until January if the thread involves the word "hint" at all. - Andrew Schreiber [more]
Unread 20-12-2007, 15:18
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Re: C coding
Sorry if this is in the wrong thread.
I am also looking to learn C before the seanson starts.
My question is: Is there a compiler I can download to learn C with?
Any help will be great.
Design. Build. Dew.
Unread 20-12-2007, 16:05
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
Re: C coding
I use dev c++ http://www.bloodshed.net/devcpp.html
It's an IDE which comes with both C and C++ compilers, and is fairly easy to set up.
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 20-12-2007, 16:07
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: C coding
I would recommend Easy C or if you are going to have a basic robot such as tank drive with a basic manipulator Mplab is pretty easy to learn the basics. It only took me about a week to learn most all the basics needed to program in regular C.
Unread 21-12-2007, 09:11
diesel's Avatar
FRC #2077
C compiler
I know a little easy C from programing my vex robot, not a lot.
I also am learning PASCAL in my computer science class.
Thank you for all your help.
Design. Build. Dew.
Unread 21-12-2007, 09:42
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: C coding
You can download easyC Pro at http://www.intelitekdownloads.com
and you can have a mentor e-mail us to request your team CD-Key.
If you are a 08 Rookie we can create a team key to get you started.
If you have a Vex robot can you prototype code in Vex mode to learn
how things work.
Unread 21-12-2007, 10:01
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: C coding
Welcome to programming! I just learned how to program a few months ago, and I'm pretty good now. If you're anything like me, then you learn by a hands on example. To get started, download the robot code off of ifirobotics.com; while at IFI, download the IFI_Loader. Next you'll need MPLAB with the C18 compiler. The main program you'll program with is User_Routines.c Just look at the code and try to figure out how it works. pwm?? are the PWM outputs on the controller. 127 is center/off. Relays are H bridges, so fwd triggers one relay, and rev triggers the other relay. If you have both on or both off, whatever you are controlling will remain off. You must have a 1 and 0 or a 0 and 1 to turn something on. In robotics, you will usually leave rev at 0 and then turn fwd on and off because of the polarity of the devices. Controls are pretty simple too, it's all in user_routines.c Good luck with programming and feel free to contact me.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 21-12-2007, 14:13
Ken Leedle Ken Leedle is offline
College Student
FRC #0706 (CyberHawks)
Ken Leedle will become famous soon enoughKen Leedle will become famous soon enough
Re: C coding
Just a minor correction: The Victors translate the RC style PWM signal (~1ms-2ms pulse) into a straight duty cycle (0-100%) and direction signal for controlling the actual FETs in their H-Bridge. The Spikes are configured similarly to an H-Bridge, but use relays instead of FETs. Relays are electromechanical switches. Notice the audible click when they are actuated.
The MPLab IDE is fairly easy to set up and use from my experience. The code FIRST gives you takes a lot of the learning curve of programming micro-controllers out of the picture and allows you to code basic functionality without knowing the particulars of the device. It may seem intimidating at first because of the sheer volume of code, but once you figure out which sections you need to be concerned with you should find programming the robot controller straightforward.
-Ken
Photoswitch coding magical hands Programming 0 17-01-2006 21:20
coding problem!! HELP! wildabyss Programming 7 21-02-2005 21:48
Pneumatic Coding Problem lasoaaro Pneumatics 11 18-02-2005 12:11
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Coding conventions Anthony Kesich Programming 20 08-01-2004 10:50
