Go to Post I wasn't pouting; just cowering in fear because I actually thought you were mad at me... I didn't want a clipboard to the head like Billfred here. - Jon K. [more]
Unread 19-12-2007, 18:23
nukelear1991 nukelear1991 is offline
AKA: Mike Poff
FRC #0858 (Delphi Demons)
Team Role: Tactician
nukelear1991 is on a distinguished road
Crab Drive
Well over here in Wyoming,Michigan things are beginning to get cold and thus... I AM CRZY ABOUT BUILD SEASON....my question is about programming the crab drive...particularly I want to do what I like to call "Doom Style" controls (Left Stick: Forward and Back and Strafe Right Stick: Turn) but am at a loss for how to program it. Please help
tank you,
Geeky Demon - Nukelear1991
Unread 20-12-2007, 15:54
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Crab Drive
we had a swerve drive last year and for are prototype it had "doom mode"this was very hard to control. We later went to a one joy stick drive. (wherever you point the joy the robot will go in the direction) However the 2 joystick drive would be far easier to program the one joystick drive is nicer for the drivers. I have yet to learn all the tricks for the swerve program. I know right know though are code did include a huge arc tan table that was a pain to get.
Unread 20-12-2007, 16:22
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Crab Drive
We have a lot of experience with crab drive and we've always set it up the same way: We use 2 joysticks. The right stick is used for normal tank-style controls, while the left stick can be moved left and right of center to cause the crab wheels to turn in that direction. We've found this quite effective.
Probably the most important piece of advice I can give for any teams considering using crab for the first time is this: you need practice. I don't care how good your drivers are at playing video games that are similar, it's different on the robot. You won't be able to take advantage of the capabilities of crab unless you practice, simple as that. So, get a prototype base up and running early in the build season for your drivers to practice with!
Unread 20-12-2007, 16:28
popo308's Avatar
AKA: Brent
Re: Crab Drive
Originally Posted by Probably the most important piece of advice I can give for any teams considering using crab for the first time is this: you [b
need[/b] practice. I don't care how good your drivers are at playing video games that are similar, it's different on the robot. You won't be able to take advantage of the capabilities of crab unless you practice, simple as that. So, get a prototype base up and running early in the build season for your drivers to practice with!
I could NOT AGREE MORE!! We went into St. Louis with no practice assuming it would not be very hard to learn in minimal time. Are driver went out there with no practice and it was terrible! GET PRACTICE!
Unread 20-12-2007, 16:35
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Crab Drive
Practice is key, but I would agree, two joysticks is probably easier in the long run!
Unread 20-12-2007, 16:42
popo308's Avatar
AKA: Brent
Re: Crab Drive
From a programing look at it i would agree two joysticks is easier to program
Unread 20-12-2007, 16:51
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Crab Drive
[quote=Dave Flowerday;662035]Probably the most important piece of advice I can give for any teams considering using crab for the first time is this: you need practice.[quote]
I couldn't agree more. True, this is espeically necessary for crab drivetrains, but it is in some degree true for ALL holonomic drive trains.
Believe me, I know Master Chief wishes he was holonomic but he isn't, so video gamers won't have much of an advantage over anyone else learning how to drive a holonomic vehicle, especially since you can't feel the G forces or even keep your frame of reference locked to the vehicle's like you can in a car.
It takes some getting used to, even for the Legendary players among us.
-q (who played too much Halo this weekend)
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 20-12-2007, 17:01
FRC #1360
Re: Crab Drive
Technically speaking..... He does have three axis of movement (Foreward-backwards, straft Left-right, turning) therefore really he is....
Although I would agree it would be completely different with the robot (especially if it isn't field centric driving)
Could you imagine try to running around as master chief with the camera turning around him all the time, and foreward, isn't the way the camera faces but whatever direction he is facing it would take a bit of getting use to it lol
Unread 20-12-2007, 21:01
AKA: Mike Poff
Re: Crab Drive
well we are hoping to have the drive built by end of second build week....which will give us time to practice.... I am going to go with the two joys and I think the controls will still be Doom Style
2009 Lansing District Event Champions
Unread 21-12-2007, 00:26
Aren_Hill's Avatar
Build Nifty Things
Re: Crab Drive
Pshh i think i did pretty good for no practice. What would have really helped was a robot that wasn't completely symmetrical so i could tell which way was forward
A guy who likes robots.
Unread 21-12-2007, 15:18
FRC #1360
Re: Crab Drive
colour codes help tell which way is foreword ( make the front and back a different colour than the rest of the bot.)
Unread 21-12-2007, 16:15
popo308's Avatar
AKA: Brent
Re: Crab Drive
Thats what we did but we colored one side with a jumbo sharpie and the other side was Al. It still was very hard though since you cant always see the bot with the rack in the way!
Unread 21-12-2007, 16:54
FRC #1360
Re: Crab Drive
lol true enough, best bet is a rectangular bot lol (but you guys didn't do that so.... lol)
Unread 21-12-2007, 18:02
popo308's Avatar
AKA: Brent
Re: Crab Drive
well when we put are arm on there it was mounted on the back run up and down with a lead screw thru a 64:1 bane bots and that made it easy because the arm was always aimed at the from so we knew what way we were going however are other arm was in the middle on a turn table so that didnt work for that one...
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
EduRobot Crab Drive OneAngryDaisy Robotics Education and Curriculum 8 03-10-2003 10:06
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
