Thread Tools |
Rating:
Display Modes |
Re: pic: Team 100 Prototype Base - Underside
C-channel has about half as much torsional strength as box tubing even though it has only one less side. |
--Wow that’s the exact dimensions ! We searched and searched for channel stock that came in these dimensions, but it didn't exist . So we just purchased a 2.25 x 1.5 block from a local metal supplier and machined a 1 x 2 slot in it. It took forever on our little mill, but our sponsor will probably be able to get it done in an afternoon.--We just cut two 0.75" long slots on either end with a 0.75" end-mill. The center slot is vertical, allowing the center wheel to be raised or lowered an 1/8 of an inch. --McMaster Carr. We had to machine them thinner and broach them, but it wasn't too hard. Just like everything else they carry the sprockets were cheap and arrived soon ![]() |
This is a really nice example of a modifiable prototype chassis. 55 lbs ain't bad, our mecanum base last year was 80 lbs, while the arm was 30 or so. With all the weight down low, we never were close to tipping over. The method of tensioning is also a pretty slick idea. How heavy are the wheels? Will you be using a similar chassis layout with the box extrusion?
Pretty cool guys. I agree with Travis. Looks extremely well designed. Wish we had ever had our acts together enough to have an offseason project as nice as that when I was on the team
![]() For those criticizing the weight, there's all kinds of weight they could easily remove. The sprocket hubs can be turned down. The gears in the AM shifters can be lightened. The big CIM's can be swapped for small CIM's. Even without swapping the CIM's, I'd say they could cut 2-5 lbs pretty easily. |
I would not worry about the 55 lb drivetrain you got there. With electronics that is a PERFECTLY acceptable weight. I like the whole setup you got here. Good job.
It's organized and simple, and very light for a drive train and frame and electronics and pneumatics. However, as Squirrel said, weight down low isn't a bad thing. We try to keep a low center of gravity and almost never tip, although the ramps were sometimes a problem and we aren't considered fast. I like how neat and clean the chains are- no tensioners. If I may, I think the motor wires might do better tied against the frame to keep them out of the way. Just my opinion. I do like the frame extending to protect the wheels in the front and back. That would be a nice place to put bumpers; mount them with bolts on either side of the wheels. And good looking welds, too, from what I can see.
#7
Sorry for bashing the weight. I spent too much time thinking about that one number. It is quite the nice system. How quick is tensioning?
Also, do you happen to know around how much the electronics board in whole weighs? I'm curious as to whether or not this thing would be lighter with a less hefty board. Very nice, and props on getting something together before the season! I know it's not easy, as all of my attempts at doing this have been shut down. Props! |
#8
A piece of plywood can be kind of heavy, or not....depending on what you use. 1/8" lauan plywood is fairly rigid, light, and not very expensive, usually available in part sheets from big building supply places.
#9
Tensioning is really easy. You just loosen three bolts and slide the bearing block into place and tighten it down. And no, the blocks don't slip. The chains will stay tight until they begin to strech. Quote:
For the competition version we may use 7075 or 7068 aluminum for the axels. Any advice on that? |
#10
Nothing too special you need to do. ours are just plain old 7075 1/2" main diameter, with 7/16" hexes on either end. No heat treatment or hardening necessaary
#11
340's proto frame weighs somewhere around there made of 3/4 bar stock. it's so bulletproof. We love it.
#12
What is being used to hold down the electronics and other stuff because in the 2007 season we screwed and bolted everything down.Bad idea it bit us in the butt big time.I heard zip ties are the best way to go.
#13
I have seen some teams use zip ties as they are easy to cut and replace, I have also seen some teams use strong Velcro, as it is even easier to change a component then zip ties. As for me, we had a little room and just put a few extra spikes on the robot unwired that way we would only have to pull the wires off the bad one and we would be good to go.
#14
http://www.chiefdelphi.com/media/papers/1998 |
#15
Looks nice, I bet you with my experience in lightening, that, I could help you loose about 10-12 off of that 55. Other then that looks nice!
| pic: Team 100 Prototype Base | =Martin=Taylor= | Extra Discussion | 8 | 21-12-2007 01:06 |
| pic: FRC294 Prototype base almost done | AdamHeard | Extra Discussion | 24 | 29-11-2007 01:12 |
| pic: Team 100 Prototype Base | =Martin=Taylor= | Extra Discussion | 11 | 10-10-2007 07:39 |
| pic: 294 Prototype Base frame rails | Borisdamole | Extra Discussion | 6 | 17-09-2007 18:19 |
| pic: FRC294 Prototype base | AdamHeard | Extra Discussion | 18 | 07-09-2007 15:22 |
