Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
View Poll Results: What's the status of your IR Board?
Ours works fine 57 72.15%
Worked but we broke it 6 7.59%
Partial operation but gets the job done 2 2.53%
Partial operation but not the important part 6 7.59%
No response at all 10 12.66%
Multiple Choice Poll. Voters: 79. You may not vote on this poll
Unread 21-12-2007, 06:59
Tally of Working IR Boards
With 1500+ teams receiving the IR board as an early holiday present it's impossible to use a thread to discover who's board is working well, who's isn't, or which ones are caught up in the holiday mail crush.
Thus a poll.
Try to answer only once per team. You can check to see if any of your pals have already answered.
Anyone who hasn't received their IR board yet, just wait until it comes then test it and give us your report.
Engineering is all about collecting meaningful data to act on.
Unread 21-12-2007, 18:44
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Tally of Working IR Boards
Do you have a preferred testing method?
Ex- Plugging into a battery, hooking it up to the 2007 RC and checking for input/output, etc.
Just checking our definition of "working."
When we first got it, some people tried simply touch two wires from a 9-volt battery to to the correct pins of the board, but with no results. Wasn't a serious test, so I'm going to wait to give a definitive answer.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 21-12-2007, 19:00
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I marked ours is fine, but I haven't tested the outputs. The LEDs turn on when I press a buttons, so I'm assumeing the outputs are also working fine.
Eric Haskins KC9JVH
Unread 21-12-2007, 19:49
Aren_Hill's Avatar
Build Nifty Things
we need to change our vote.... it did work then yeah.... watch wear bare wire ends go
A guy who likes robots.
Unread 21-12-2007, 19:53
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
so who knows where to get a new 5v regulator??
eh?
Unread 21-12-2007, 20:59
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Ours reads the repeating signals from channel up, channel down, volume up, and volume down. The lateral range seems to be pretty good - it reads from nearly all directions from the half-sphere surrounding it. Perhaps this could be coupled with the camera technology from last year that uses the signals to triangulate position?
Hi!
Unread 21-12-2007, 21:29
A full checkout would be as you say--power it, train it, have it respond correctly to the remote, monitor the outputs with a scope or an RC. Post details about any failures and what worked/what failed. Normal room lighting conditions, not direct sunlight or any stress tests like that.
A basic checkout would be all but checking the digital outputs since that can be done pretty quickly and with the fewest parts.
If you have the equipment to do a full test, then do that and report.
If you can do a basic test quickly then a full test sometime later, then test the basics and report. If the digital outputs later turn out to be faulty then post about the problem and you can have a second teammate put the changed answer into the poll.
Also, use "Worked and we broke it" even if you're not sure you actually broke it as long as it worked then stopped working. You can post any useful details about that experience too.
Anyone with other ideas about what else we could be looking at?
Unread 21-12-2007, 22:08
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
2273 up here in BC reccived our IR board today, and it worked flawlessly. Programmed the random old remote I found burried under some stuff years ago.
All the outputs worked, and responded clearly. Range is really nice on these vishay reccivers, making me think even more that this is some kind of field element, that will be triggered by a transmitter on the bot. Also, they decided to code protect the pic in it . There goes my fun of trying to decompile the hex and fetch some information about the game.
Unread 21-12-2007, 23:54
popo308's Avatar
AKA: Brent
We had are IR board actually hooked into are RC and it was sending/receiving power and data back and forth until it randomly went up in smoke?? i would not recommend it until we get the official use of this board with diagnostics.
Unread 22-12-2007, 01:00
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Our board hasn't had any problems yet. It took the first remote which we programmed it with and has been properly functioning since.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 22-12-2007, 20:53
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
2158, 2468, and 2538 got together today for a pre-season workshop on programming basics for FIRST. Our last project of the day was hooking up the IR sensor to a Vex bot, which allowed us to drive our vex bot around with a TV remote It was definitely exciting to get it working, and surprisingly easy. I'm definitely looking forward to whatever we have to do with it in the actual competition....only 14 days to go!
Here's a video of our working vex bot with IR sensor: http://www.youtube.com/watch?v=XUx2w3J_jDk
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 22-12-2007, 21:25
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
can you do this with the big bot now???
Unread 22-12-2007, 21:46
Engineering Mentor
Oooh....now there's an idea, we definitely could
Maybe I'll do that a little later tonight if I can get my hands on our robot from last year
Unread 22-12-2007, 22:57
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
You can't just do it with that robot David showed us that spun around fast enough to give him a static shock? Surely that would be lots of fun to add little motors onto to pick up sodas.
Unread 23-12-2007, 00:31
popo308's Avatar
AKA: Brent
does anyone know where to get the little 5v regulator for the board?
are 5v regulator went up in smoke..
Game Hint Tally T3_1565 Rumor Mill 137 29-12-2007 23:11
Camera Boards Inoperational Programming 6 20-01-2007 12:57
OI Boards? Jake M Robot Showcase 1 28-11-2006 20:02
Cost Tally Andy B Kit & Additional Hardware 1 10-02-2005 10:54
Control Boards tenfour General Forum 3 01-03-2004 20:01
