| View Poll Results: What version control tool(s) do you use? | |||
| SVN |
22 | 61.11% |
| CVS |
6 | 16.67% |
| VSS |
0 | 0% |
| Other please post |
5 | 13.89% |
| None |
3 | 8.33% |
| Voters: 36. You may not vote on this poll | |||
#16
Re: What version control tool(s) do you use?
Ok, Linux based probably wasn't the best term, but I don't own any Linux boxes and really have almost no experiance with Linux. I can get around in linux, but i know Windows. If it doesn't have decent Windows servers and tools then I'm not going to use it. I already plan to have our own network setup for the season. I could have a local machine hosting something, but I want to be able to access our repository remotely and the school network too locked down to do that. I like SVN, but at this poit I need somthing that gets along with IIS since I'm already hosting websites at my house. If I could find a way to get both my hosting virtual machine, and an SVN virtual machine on port 80 with the same public IP, then I'd be happy with Apache/SVN/TortoiseSVN, but as far as I know I can't do that. |
#17
Does anyone else use Git? Oh, and that reminds me, (and isn't important enough for its own topic), is there a GUIless uploader for windows? |
#18
Voltage 386 uses a CVSNT with Tortise solution for their software and website code. Works brilliantly! I've since convinced the higher-ups at my office to move their SourceSafe (really bad, I know) repositories to CVS.
#19
Check out Assembla: http://www.assembla.com
FAQ page here: http://www.assembla.com/wiki/show/breakoutdocs/FAQ We're just starting out with it, so I can't totally vouch for it, but it looks promising. It's totally free for small groups! Also, not sure if it requires anything other than port 80, but it is all web-based, so you might be okay. Oh - and you can make your space totally private, if you so desire (or if you're using Kevin's code )Last edited by Abrakadabra : 22-12-2007 at 02:35. |
| What programming tool does your team use? | ham90mack | Programming | 15 | 13-10-2007 15:52 |
| What tool are you using to make weight? | EricH | General Forum | 40 | 27-02-2006 19:46 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| What view do you use? | Brandon Martus | CD Forum Support | 10 | 02-12-2003 17:32 |
| What do you YOU use your bins for? | AlbertW | General Forum | 40 | 13-04-2003 04:18 |
