Go to Post In the end, if our products are crap, then people will not buy them. This is the risk of doing business, and the foundation of capitalism. - Andy Baker [more]
Unread 21-12-2007, 14:25
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Creating Windows GUIs with C++
Originally Posted by slavik262 View Post
So much for being able to distribute just my executable.
Oh, that's one advantage of WTL I forgot to mention. WTL requires no additional DLLs unless you explicitly decide to link to additional libraries. And in that case you know what you require. Also, your application can be quite small since you don't drag in things you're not using.
Unread 21-12-2007, 15:18
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Hang on, were you able to send it to your friends?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 21-12-2007, 16:13
Wow! Now I remember why I gave up on Win32 so long ago. I was in pretty much you exact position 5 years ago. After running into so many "gotchas" (I had a different word for them), I decided to cut my losses. I switched to Python and haven't looked back.
I won't start a holy war thread here, but you may want to carefully consider exactly what you want to do, and then compare your available language options before committing.
I would also like to highly recommend "How to Think Like a Computer Scientist" by Allen Downey. You can download it for free at http://www.greenteapress.com/thinkpython/
Allen Downey is a prof at Olin College (my alma mater). Several years ago he wrote a Java version of the book and copy-lefted it. Someone took the book, revised it for Python, and rereleased it. Allen then read this book and learned Python.
... Yes, he learned Python by reading his own book!
It has some chapters that deal with a little bit of user interfacing, so it shouldn't be hard at all to get going.
Good luck!
Eric
Unread 22-12-2007, 10:47
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Not to be a killjoy but I know someone who uses python and his application is fairly slow, for the simplest of programs you have to package the exe with tons of files, it just seems like a hassle. If you are going to learn a different language to do it C# is the way to go. C# is the most similar to C++ as well
Is easyC compatible with windows vista team877 Programming 10 12-02-2007 12:43
What to do with an old Windows 3.10 laptop? Elgin Clock IT / Communications 13 14-07-2005 17:45
Prob. With Windows 2k Staz Programming 2 15-01-2005 10:15
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Need Help With Windows Applications In C++ Hailfire Programming 9 05-01-2003 10:13
