Go to Post I might be a nerd, but I am definitely a pi freak! - Courtneyb1023 [more]
View Poll Results: What version control tool(s) do you use?
SVN 22 61.11%
CVS 6 16.67%
VSS 0 0%
Other please post 5 13.89%
None 3 8.33%
Voters: 36. You may not vote on this poll
Unread 21-12-2007, 13:46
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: What version control tool(s) do you use?
Originally Posted by whitetiger0990 View Post
I wouldn't say it is Linux based, it was just made by Linus, and the tools haven't been ported (besides cygwin and msysgit).
We had a problem with only having ports 80/443 and CAD. We wanted a centralized CAD server that we could access from wherever, but that didn't pan out (so we set up a small network of our CAD computers when we work on that.) Apache has an SVN thing, which works on port 80, but I'm not sure about its limitations. I like Git because it doesn't have to be centralized. Just go into a directory, `git --init`, and you're set. If you do make it centralized so you don't have to do it sneakernet, you can have a cool web interface like this: http://repo.or.cz/ . Can't show you ours, because of Kevin's code. *shrugs*
Ok, Linux based probably wasn't the best term, but I don't own any Linux boxes and really have almost no experiance with Linux. I can get around in linux, but i know Windows. If it doesn't have decent Windows servers and tools then I'm not going to use it.
I already plan to have our own network setup for the season. I could have a local machine hosting something, but I want to be able to access our repository remotely and the school network too locked down to do that.
I like SVN, but at this poit I need somthing that gets along with IIS since I'm already hosting websites at my house. If I could find a way to get both my hosting virtual machine, and an SVN virtual machine on port 80 with the same public IP, then I'd be happy with Apache/SVN/TortoiseSVN, but as far as I know I can't do that.
Eric Haskins KC9JVH
Unread 21-12-2007, 17:57
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
The Linux tools work on Windows, if you can use the command line, you can use them them. Then again, it's all preference, I don't like things that require using my mouse...
Does anyone else use Git?
Oh, and that reminds me, (and isn't important enough for its own topic), is there a GUIless uploader for windows?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 22-12-2007, 00:59
chrisstruttmann chrisstruttmann is offline
FRC #0386 (Team Voltage)
chrisstruttmann will become famous soon enough
Send a message via AIM to chrisstruttmann
Voltage 386 uses a CVSNT with Tortise solution for their software and website code. Works brilliantly! I've since convinced the higher-ups at my office to move their SourceSafe (really bad, I know) repositories to CVS.
Unread 22-12-2007, 02:14
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Check out Assembla: http://www.assembla.com
FAQ page here: http://www.assembla.com/wiki/show/breakoutdocs/FAQ
We're just starting out with it, so I can't totally vouch for it, but it looks promising. It's totally free for small groups!
Also, not sure if it requires anything other than port 80, but it is all web-based, so you might be okay.
Oh - and you can make your space totally private, if you so desire (or if you're using Kevin's code )
What programming tool does your team use? ham90mack Programming 15 13-10-2007 15:52
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
What view do you use? Brandon Martus CD Forum Support 10 02-12-2003 17:32
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
