Go to Post We may not build the best robots but we're building better students in the long run and means much much more. - Koko Ed [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 21-12-2007, 19:23
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Hosting multiple sites in multiple VMs
So I'm currently hosting 3 websites in a single virtual machine. I would like to move each site into its own VM, but I only have one public IP. I currently have all traffic on port 80 being forwarded by my router(Linksys wrt54g I believe) to my hosting VM.
Is it possible to redirect port 80 traffic to different IPs based on the destination hostname? The same way you can set site bindings to one hostname in IIS.
Thanks,
Eric Haskins
Eric Haskins KC9JVH
Unread 21-12-2007, 19:30
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Hosting multiple sites in multiple VMs
yes octagate.com sells a "soft-switch" which does that. I have used the demo and it works nice
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 21-12-2007, 19:38
AKA: Eric Haskins
Thats the type of thing I'm looking for, but the $500 price tag is more than I'd like to spend.
Since the only non-personal site I'm hosting is my FRC team site, getting more than about $100-$150 really isn't possible.
Eric Haskins KC9JVH
Unread 21-12-2007, 19:55
Scott L.'s Avatar
quick google search found this. http://www.smithfam.com/wtk/RedirectBoss/
lot cheaper than octagate.
Unread 21-12-2007, 20:02
AKA: Eric Haskins
If I understand what that product does, it just redirects the client. The issue with that is that to get to another machine(or virtual machine) I would need to redirect to another port, and many places block ports other than 80.
Eric Haskins KC9JVH
Unread 22-12-2007, 00:53
chrisstruttmann chrisstruttmann is offline
FRC #0386 (Team Voltage)
chrisstruttmann will become famous soon enough
Send a message via AIM to chrisstruttmann
The short answer is no.
The long answer is yes (using systems similar to those noted above) but it will be more work and maintenance than you want to take care of not to mention slow your sites down to the same speed as if they were on the same VM.
If it's efficiency you're looking for and you're running on IIS 6 (as much trouble as it's given, it's still a decent web-server), try creating multiple application pools. Works great for some of my more intensive stuff I do at work.
ALSO keep in mind that the more VMs you have running, the more ACTUAL CPU will be used. I've decided that VMs aren't the holy grail.
--Chris
Unread 22-12-2007, 01:09
AKA: Eric Haskins
--Chris
The primary reason I currently run in a VM, and want to move to more, is for isolation.
I know that there is a lot of overheard for VMs, but since I'm running a Core 2 Quad 2.4ghz Q6600, with 4gb of ram(soon it will be 8gb), that overhead is not a significant concern.
Eric Haskins KC9JVH
Multiple Files EricWilliams Programming 4 30-03-2005 15:51
Multiple tetras Andrew Blair Rules/Strategy 28 29-03-2005 21:10
Multiple-Motors echos Motors 8 11-01-2004 17:34
Multiple Regionals archiver 1999 55 23-06-2002 22:26
