Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
Unread 24-12-2007, 11:59
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
How much metal to get?
Hello,
I have a general idea of how much metal to get and to be safe I came up with these numbers:
Square aluminum 1"x1"x1/16" extrusion- # of 6' pieces: 10 should last us a while with prototyping and pre-season robot/training with weleding and what not.
Aluminum sheet: I am having a bit of trouble with this. How much? of 5052? of 6061? what thickness?
The place we will be getting it from has up to 0.19 inch thickness.
Aluminum plate at all? I have heard that 1/4" aluminum plate would be good to have. What would we use this for? structural purposes?
FYI, We will be using www.discountsteel.com to get our metal from. They are a local business and we would be able to go over there with a pickup and not have to pay for shipping.
thank you in advance, Vivek and team2264
EDIT: How much do you think we would have to spend?
"we don't build robots, we build people"
Unread 24-12-2007, 12:05
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: How much metal to get?
Originally Posted by vivek16 View Post
Hello,
Why not wait until you decide what you need if they are local? This only works if they are close and if they only keep a large inventory.
Unread 24-12-2007, 12:06
vivek16's Avatar
AKA: vivek
That is true but wouldn't it be better to not waste any time and stock up on some materials before hand?
thanks, vivek
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You can buy a bunch of metal now, but you really ought to wait until you know what need....especially for stuff like 1" square tubing that you can buy at your local hardware store.
I can't think of many uses for 1/4" aluminum, but I can for 1/16" thru 1/8", but mostly because we have access to some machinery that can be used to make it into neat shapes.
Again, I suggest you wait on ordering metal until you make at least a preliminary design for the robot, unless you have unlimited funds and can afford to buy stuff you won't use.
Unread 24-12-2007, 13:06
Best Available Data
FRC #1778 (Chill Out!)
Hello,
As for sheet, we acquired an 8x4 sheet of .25" aluminum our rookie year, and haven't used it since 2005. If you have a vested interest in making your robot weigh less than 120 pounds, it's pretty hard stuff to use, even if you fill it with holes.
In the end, it really depends on what you're building. In 2006 we probably used at least 15 feet of .5"x.5"x.125" angle, but last year we barely used any.
However, if you honestly can't wait for the season to start, look at what you used last year. If you've got a similar crew designing your robot, you'll probably use similar materials.
Unread 24-12-2007, 13:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
All square aluminum tube is extruded. Or most all. It's just not fancy extrusion. That said, 1/16" wall 1"x1" square tube isn't my first choice for structural material. For anything seeing over a moderate load, it's probably actually my last choice. Certainly, I don't think you'd need 60' of it unless you're going to prototype your entire robot out of it and then make another one out of 1/8" wall aluminum. It is possible to weld it, but you need to make sure you get an alloy with good weldability. 6061 and 6063 are god choices and you'll likely find square tube in those alloys. However, you might also find it in 2024 or other alloys which are much harder to work with. Also remember that any aluminum welding you do is quite likely to ruin your temper for a fair distance around the weld.
Unread 24-12-2007, 13:48
run the trap!!!
Team Role: Human Player
My advice for you would be to find a place that sells scrap metal and buy a whole bunch of cheap stuff. Its better to have an assortment than a lot of the same thing.
But if you do decide to get new metal, than I would get 5' of 1/16" and 5' of 1/8". 1/16" is very useful because it is light, but as Kevin said it can't carry a lot of force. I know we used a lot of both last year.
As for plate I have found that 1/8" is a nice balance between heavy-rigid 1/4" and light-flimsy 1/16". I would get a fairly large piece of that, maybe 2'x2'. I would also get a small piece of 1/4", it is very useful when making gearboxes and bearing-mounts. Maybe get a 1.5'x1.5' piece. I myself try to avoid sheet metal. It takes special knowledge and tools to use it successfully.
Expect to spend $200. But it really depends on where your getting it from and of course how much .
-Philip J. Fry
Unread 24-12-2007, 13:55
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
For starters, find out what the standard length of tubing is that your supplier carries. In all likelihood it's 20 feet. Buy as many stock pieces as possible to avoid being charged for cuts, and partial pieces. As your quantity and poundage go up, your price goes significantly down.
I'm sure most people already know this, but don't use McMaster for any type of 6061 Al. I got a quote from a local supplier that's over $1300 cheaper than the same thing would be from McMaster.
If you want to make a frame out of 1x1, use 1/8" wall thickness. I would reccomend 1x2.
It is a good idea to stock up on metal prior to build, but only if you know what you will need.
We're purchasing a lot of metal now, to supply three teams--just so we don't have to wait for it. We're getting 100 feet each of 1x1x0.125 1x1x0.0625 1x2x0.0625 1x2x0.125, plus a bunch of solid bar/round stock, and a couple 4x8 sheets of thin Al plate.
Purchasing a ton of metal will work for us because we know our frame will be made out of 1x2 with some 1x1, and that any subframe/manipulator is also likely to use 1x1 and 1x2. We run through 1x1 and 1x2 tubing so fast that 100 feet of each might barely get us through the end of the year.
I would say that the tubing should be significantly less than this--somewhere in the area of $70-100. The plate will be what gets expensive real quick. Unless he's ordering a full sheet he's going to get charged a whole lot to have a smaller piece cut out of a full sheet.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-12-2007, 14:19
AdamHeard's Avatar
Lead Mentor
Originally Posted by Cory View Post
We're purchasing a lot of metal now, to supply three teams--just so we don't have to wait for it. We're getting 100 feet each of 1x1x0.125 1x1x0.625 1x2x0.0625 1x2x0.125, plus a bunch of solid bar/round stock, and a couple 4x8 sheets of thin Al plate.
Ooooh.... Care to let us know who is joining you and RAWC?
Unread 24-12-2007, 14:37
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you having milling machine/CNC facilities, then using 0.250" aluminum can have its uses in drivetrain/gearbox applications, if you like to mill pockets into it to save weight.
But if you really want to build a lot of stuff out of plates/sheets, I'd look into getting lots of Lexan (polycarbonate). 4'x4' sheets with thickness of 0.0625", 0.125", 0.250", and 0.375" are all great to have in stock.
I'd suggest that you stock up on some of the parts that Cory has described (although I'd add 0.125" and 0.0625" wall aluminum angle to that list), but in general just go to a local metal supply and buy out all their aluminum scrap. Sometimes it's just amazingly useful to have pieces of aluminum in all shapes and sizes.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-12-2007, 15:16
Cory's Avatar
AKA: Cory McBride
Haha. I was wondering how long it would take for someone to notice that.
No third team. Just the other team (1868) that's sponsored by Ames and works in our lab with us.
2001-2004: Team 100
Unread 25-12-2007, 18:18
I wouldn't make a drive frame out of 1"x1"x1/16". Period. Superstructure, you bet, if it won't see a lot of hits or needs to be light. See 330's 2006 shooter frame or 2007 ramp frames for an example.
Typical drive for the BeachBots is 1"x1.5"(or 2")x1/8" aluminum. Superstructure may be the same and/or (the last two years) 1"x1"x1/16".
Why you don't use thinwall is simple: It doesn't like holes. You can only put functional holes in if you want it to last. No speed holes here.
Unread 25-12-2007, 19:34
Aren_Hill's Avatar
Build Nifty Things
I'd like to defend 1x1x.0625" tubing a bit.
What material you use for your base totally depends on what type of base it is.
Such as us (1625) wildstang (111), and the BEAST (71) who had swerve drives this past year. Our robot used 1x1x.0625" for the frame and i believe 111 and 71 did also, just because of what had to fit and how many supporting members are needed.
If we use a different drivetrain i'm pretty confident we'll use other materials.
A guy who likes robots.
Unread 26-12-2007, 12:46
Dick Linn's Avatar
no team (Synergy)
Our supplier has a pile of "shorts and dings", sometimes known as "drops". You can sometimes get short pieces of odds and ends at reduced price, or at least not have to buy a 20 foot stick of everything. This is very useful if you need a couple of inches of thick stuff for a bracket of something.
Overall, we've found 1 x 1 x 1/8" square tube very useful, with occasional uses for 3/4 x 3/4 x 1/8". We usually have a collection of 1/8" thick angle - 1/2", 3/4", 1" and maybe 1 1/4" or 1 1/2". We generally don't buy more than one 20 ft. piece of anything until we know our design. We don't stock much plate due to the cost.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 26-12-2007, 22:16
The folks who don't like the 1/16" thickness don't like it in a particular application. Namely, the drivetrain. For a swerve, a different frame is needed from a 6-wheel. If you need extra strength at a light wait, 1/16" is great.
My team has only used it for superstructure, primarily because we don't like the loads it'll see down low.
How much traffic does your team's website get? artdutra04 Website Design/Showcase 10 08-02-2006 15:21
How much sleep are you going to get??? ttedrow General Forum 34 11-01-2004 02:27
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
How much sleep did YOU get? Erin Rapacki Championship Event 24 21-05-2002 15:43
