Go to Post keep making a difference out there everyone...slowly but surely everyone will catch onto FIRST and then the world will be a better place :) - tiffany34990 [more]
View Poll Results: What's the status of your IR Board?
Ours works fine 57 72.15%
Worked but we broke it 6 7.59%
Partial operation but gets the job done 2 2.53%
Partial operation but not the important part 6 7.59%
No response at all 10 12.66%
Multiple Choice Poll. Voters: 79. You may not vote on this poll
Unread 23-12-2007, 04:31
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Tally of Working IR Boards
I put "Partial operation but gets the job done"
just because it worked fine before, and seems to work fine after repair.
I did test the outputs before with a multimeter.
I still have to test them now after repair. I'll report back when I've done that.
Unread 23-12-2007, 08:47
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Ours works as advertised .......
No issues ......
Ed Sparks
MECH TECH FRC-3959
Unread 24-12-2007, 12:29
Aarnat's Avatar
Aarnat Aarnat is offline
Senior Captain
AKA: Aaron
FRC #2199 (Robo-Lions)
Aarnat will become famous soon enoughAarnat will become famous soon enough
The Robo-Lion's (2199) IR board doesn't work.
The board turn's on an the error LED turns on. When we try to program it ( giving it power after holding down the program button and holding the button for 2 seconds as indicated by the manual), the LED turn's on (and then off when we release the button), but doesn't flash to indicate that it is ready to program. The error LED doesn't flash to indicate that there is a problem at all, but there is obviously a problem if it can't program. Several people have tryed to getting it to work but no sucess. We think it is a defective one, but if you know otherwise tell me.
Thanks,
Aarnat
Unread 24-12-2007, 12:43
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Wink Re: Tally of Working IR Boards
Thanks,
Aarnat
The instructions are a little bit confusing - the error LED will "blink off," then one second later, the CMD0 LED comes on. So, you shouldn't be expecting the error LED to come back on like a "full blink cycle" or anything like that. Is your CMD0 LED coming on 1 second after you release the PRGM button? Just don't be expecting the error LED to come back on again after it goes off....
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 24-12-2007, 12:55
Aarnat's Avatar
Senior Captain
AKA: Aaron
richardmcc2,
Once we release the programming button, everything stops: no LED's light or blink or anything.
Unread 24-12-2007, 14:46
Engineering Mentor
richardmcc2,
Hmm, I guess you may be right then. As long as you're holding the programming button for 2 seconds after powering up and then releasing, then the board may need to be flashed with the firmware again via the programming port, which probably has to be done by DivSys or FIRST.
Unread 26-12-2007, 01:01
keen101's Avatar
Ubuntu Linux User
Your LED's aren't backwards are they?
you could test them by taking a spare LED and touching it's leads the opposite way to where the LED is soldered.
Unread 26-12-2007, 19:51
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Originally Posted by richardmcc2 View Post
Here's a video of our working vex bot with IR sensor: http://www.youtube.com/watch?v=XUx2w3J_jDk
Richardmcc2,
I couldn't help but notice in your video the output led's flash repeatly.
The operation of the IR is when it recieves a learned command, it toggles an output for 100msec.
Your outputs in your video flash.
Is that because:
1. Your remote control is repeatly sending a signal to the IR controller?
2. Your operator "thumb" is pressing on the remote control repeatly?
The remote control we are using only sends one IR command per-press of the button, even if you hold it down for any length of time.
Just curious...
BTY, our board works great out of the box.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 27-12-2007, 11:18
Anne_droid's Avatar
Anne_droid Anne_droid is offline
AKA: Anne Mitzel
FRC #0451 (The Cat Attack)
Anne_droid is an unknown quantity at this point
Originally Posted by popo308 View Post
does anyone know where to get the little 5v regulator for the board?
are 5v regulator went up in smoke..
DigiKey or Mouser (online), unless you are fortunate enough to have a real electronics store in your area (Radio Shack doesn't count).
Unread 27-12-2007, 15:48
keen101's Avatar
Ubuntu Linux User
Originally Posted by Chris_Elston View Post
Richardmcc2,
Is that because:
1. Your remote control is repeatedly sending a signal to the IR controller?
I would assume it's repeatedly sending the signal.
I have tested two different remotes with our board. One was a cheap DVD remote that only sent the signal once. The second repeatedly sent the signal. If you read the IR manual it talks about using a remote that repeatedly sends the signal.
Unread 26-01-2008, 16:52
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Ours did work, but now magically doesn't. We have no idea why. Would it be best to contact FIRST or buy a new one?
Unread 26-01-2008, 16:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Has anyone used it for auto-mode changes yet? Perhaps on an old bot?
-Dustin Benedict
Unread 26-01-2008, 21:01
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
our first board fried (even replaced the voltage regulator).
We ordered two replacements from IFI -- the first one worked like a charm -- haven't tested the 2nd yet.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 26-01-2008, 22:45
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I jumpered the on board regulator, and now feed the board with 5 volts. Works fine now, and worked fine before I accidentally reversed the polarity.
Unread 27-01-2008, 11:27
Nuggets08 Nuggets08 is offline
FRC #1737 (Project X Robotics)
Nuggets08 is on a distinguished road
Our first IR board was DOA, it seemed that the 5V regulator got fried before it even got to us. We got another one, and now it works great. We used the remote on it from 50 ft away, which was nice.
-Nuggets
Project X Robotics
Team 1737
Excelsior Springs, MO
Attending: KC-Metro Regional
Project Manager, Lead Programmer
Game Hint Tally T3_1565 Rumor Mill 137 29-12-2007 23:11
Camera Boards Inoperational Programming 6 20-01-2007 12:57
OI Boards? Jake M Robot Showcase 1 28-11-2006 20:02
Cost Tally Andy B Kit & Additional Hardware 1 10-02-2005 10:54
Control Boards tenfour General Forum 3 01-03-2004 20:01
