Go to Post I like to divide checklists like this into "stuff I have to do before applying power" and "stuff I'll find faster by watching it fail". - EricVanWyk [more]
Unread 08-03-2008, 07:42
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
Of the teams that used my code last week, did any bugs pop up?
We used Kevin's code at the Week 1 BAE Systems Granite State Regional, and had no bugs at all pop up in Kevin's code! (Wish we could say the same for our code! )
We used Kevin's beta 3.0+ code (as of 2 Feb 2008) with the following features / modules:
  • ADC usage to periodically sample absolute magnetic encoders on our primary drive wheels
  • ADC usage to periodically sample absolute magnetic encoders for steering position on our "Speed Racer" robot configuration
  • ADC usage to periodically sample a multi-turn potentiometer on our arm for our hurdling robot configuration ("Fezzik")
  • Gyro usage for current heading on both robot configurations
  • Our own "fast loop" at 100Hz running in Autonomous_Spin and Teleop_Spin for increased PID responsiveness, using a timer, as suggested by Kevin in another thread
All of the above worked beautifully! Autonomous modes on both robot configurations behaved very well, and we never had any troubles that we can attribute to Kevin's code. (We did, of course, have our share of problems, including tracking down a flaky magnetic encoder, our own bugs in our own code, and an IR board that lost its programming before our last qualifying match.)
Thanks, Kevin, for all of your work on the "new and improved" FRC code!
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 09-03-2008, 15:15
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Cool! Thanks for letting me know.
You're welcome.
-Kevin
Kevin Watson
http://kevin.org
Unread 09-03-2008, 22:04
BotnEyedJoe BotnEyedJoe is offline
AKA: Joe Hurler
BotnEyedJoe is an unknown quantity at this point
This new code is a wonderful improvement. I especially like its straightforward approach, and simplified way of inserting mission-specific code. It has been a joy to use. But there's still something I'm trying to figure out about it, so if anyone can help, I'd be grateful...
It started with trying to figure out something unexpected which happens when we hold down the "Disable" button on our competition port dongle while booting the RC. In the function main() in ifi_frc.c, the one-time initializations occur of couse, and the "while (TRUE)" loop is entered, but to our surprise, we see "Teleop_Init()" execute, where we would have expected "Disabled_Init()" to be chosen instead.
Now the first thing inside the "while (TRUE)" loop is the test "if (disabled_mode)...", where disabled_mode is a field inside rxdata. But I don't see where rxdata has been set at this point. It appears to be set later on through calls to Getdata(&rxdata), once statusflag.NEW_SPI_DATA becomes 1.
Could someone enlighten me as to what I'm missing about the initialization of rxdata, specifically fields disabled_mode and autonomous_mode? Or is this, like, maybe a problem?
If you've read this far, thanks, but while we are in this vicinity, I also have a question about "statusflag.NEW_SPI_DATA", which before the "while (TRUE)" loop is set to 0. I assume it is really "volatile" even though I can't find that in any of its declarations (again I'm missing something?), but if it isn't 1 by the time we go through that loop the first time, wouldn't a _Spin() function be called before its corresponding _Init()? Is there some mechanism preventing this, or do we need to take this possibility into account in programming the _Spin() functions?
Anyway and everyway possible, Kudos to Kevin, he has made our world more enjoyable through his efforts!
Unread 10-03-2008, 02:40
FRC #2429
The problem is that the main loop is entered before the master processor has sent the first packet, and because neither the disabled or autonomous bits are set, the software first enters teleoperation mode. One quick way to get the behavior you describe would be to modify the code in main() to wait for the first packet before dumping into the while(TRUE) loop. Something like this should work:
statusflag.NEW_SPI_DATA =0;
while(statusflag.NEW_SPI_DATA ==0);
while(TRUE)
-Kevin
Kevin Watson
http://kevin.org
Unread 10-03-2008, 05:44
AKA: Joe Hurler
... And, once NEW_SPI_DATA becomes set, is a Getdata() call also needed, so that disabled_mode and autonomous_mode become set based on the contents of the newly-arrived packet?
Unread 10-03-2008, 10:20
We ran your code successfully at the San Diego regional.
Unread 10-03-2008, 13:15
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Kevin...
Team 812, The Midnight Mechanics from the Preuss School at UCSD used you code as the basis of there robot for the San Diego regionals and the team received the Chairman's Award.
Thank you very much for your contribution to the First Robotics Program.
Unread 10-03-2008, 18:58
rdaugherty rdaugherty is offline
FRC #0435 (RoboDogs)
rdaugherty is an unknown quantity at this point
Kevin,
Just to add to the positive feedback, team 435 used your new code this year. (I think we are at least one version behind.) We had no problems which you have not already fixed. In addition to the base 3.0+ compatible code, we also used the EEPROM, tracking menu, and portions of the robot.c code from previous years.
The structure and starting sensor code has clearly been a great boon to the team's development of both teleop and automonous code.
So please take this as another great big thank you from another appreciative team.
Rich Daugherty
Programming Mentor - Team 435 RoboDogs
SE Raleigh High School - Raleigh, NC
Unread 10-03-2008, 21:44
FRC #2429
Yes, I forgot to include that little detail <sheepish grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-03-2008, 13:08
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
does anyone know a site were i don't have 2 download anything to see the new code, because im at school and they won't let me save the kind of files that r posted on kevin
thnxs in advance
if you know the site just message me
thnxs again
Is now an engineer thanks to FIRST.
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
