Go to Post It doesn't make a team better if they have just one sponsor or if they have 100 sponsors. However, you should commend a team who struggled to pay the bill with a list of sponsors one hundred long for showing their strength, perseverance and love for participating in the FIRST robotics program. - MikeDubreuil [more]
Unread 26-12-2007, 21:52
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by EHaskins View Post
I believe that headers within <>s are found in "c:\mcc18\h" by default. If you look adc.h, delays.h, and stdio.h, are all located there.
So I have learned.
Well, as long as I keep learning, I don't mind hanging it out there. At least now I know more than I did this morning.
Originally Posted by Joe Ross View Post
adc.h should be included with the compiler. Are the include and library paths set? In the older MPLAB, the settings would be in project->build->project and would be:
C:MCC18\h for Include Path
C:MCC18\lib for Library Path
Originally Posted by Kevin Watson View Post
Actually it's <adc.h> and <delays.h>. The <> tells the compiler to use it's own header files (usually in mcc18\h) instead of looking in the build directory. Once the code is stable and I have a sense that teams will want to use it, I'll build versions with support for some of my other code, like the ADC, gyro, encoder, etc.
-Kevin
That explains what I didn't understand. Thanks.
I am looking forward to the new builds that include your: ADC, gyro, encoder, PWM etc. I have learned a lot this summer by working with those versions from previous years and getting them to work with my Vex.
As of right now, I can fairly confidently say, we will use your code this year as long as the programmers don't decide to go with EasyC Pro. I need to let them make the choice.
Unread 26-12-2007, 21:33
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by billbo911 View Post
I noticed a couple "#include" statement for files that do not exist. For example, in "ifi_code.c" is a call to include "adc.h" and <delay.h>. I'm not clear on the differences when the "<xxxx>" is used, but it sure would be nice to have your "adc" code included.
-Kevin
Kevin Watson
http://kevin.org
Unread 26-12-2007, 16:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The layout looks a lot more straightforward than the standard IFI. To address the concerns of those who would rather have a single Spin function, you always have the option of defining your own Default_Spin() function and calling it from each of the other Spin functions. I really think that choice comes down to six of one and a half dozen of the other. If you'd rather have a single spin function and switch inside of it on flags, you're duplicating the mode determining logic already defined in the main loop for the privilege of shoving all your spinning code into one large function. I don't think saving a function call to a Default_Spin() routine is really worth that hassle.
Unread 26-12-2007, 21:26
FRC #2429
If I understood the included "C18 ISR.pdf", we should be fairly safe and not have to modify it at all, correct?
Yes, as long as you keep your code within the ISRs that I've provided in interrupts.c and timers.c, you should be fine.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-12-2007, 22:48
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Great design. Just a word about words.
The *_Spin() functions are great -- it's just that in my little robot namespace world "spin" refers to when the robot turns around its axis. (We set up the joystick so one of the buttons calls the spin() routine that makes the robot turn on a dime.) When I saw "spin" that's what I thought it meant; I had to study the code to see what it really meant.
Is "spin" so standard in the embedded world that I should invent a new term for "turning on a dime"? (Diming? What if you only turn 90 degrees? Is that Quartering?) Or can we name the _Spin() functions something else? _WhileWeAreWaitingForNewData()? _StudyHall()? _Loitering()?
Sorry for the bad jokes, but I'm seriously concerned about overloading the term "spin"...
It just me?
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 29-12-2007, 23:21
FRC #2429
Originally Posted by gnormhurst View Post
Is "spin" so standard in the embedded world?
In computer science a "spin loop" is a way to waste time while waiting for something to happen.
-Kevin
Kevin Watson
http://kevin.org
Unread 26-12-2007, 10:45
FRC #2429
Originally Posted by Jon236 View Post
Had a little problem compiling...
It's not backward compatible with the 2.4 compiler. I'll create a 2.4 friendly version if people like the layout. The update to 3.1 is available on Microchip's website:
http://ww1.microchip.com/downloads/e...-doc-v3_10.exe
-Kevin
Kevin Watson
http://kevin.org
Unread 31-12-2007, 18:16
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Wow Kevin! I love it already. Everything is so well organized and everything is incorporated. This will be a really good tool for rookies as well as veteran teams . I will definitely be using this on our 2008 robot
Unread 04-01-2008, 11:11
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Kevin:
Here are some change that I made to your serial routine to set the baudrate correctly for any processor speed.
in serial_port.c
#ifdef ENABLE_SERIAL_PORT_ONE
void Init_Serial_Port_One(void)
// Start by initializing the serial port with code
// common to receive and transmit functions
// SPBRG = BAUD_38400 ; // baud rate generator register [251]
SPBRG = SPBRG_VAL_1; // defined in hardware.h
#ifdef USART1_USE_BRGH_LOW
TXSTAbits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
#else // 0: low speed
TXSTAbits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
#endif // 1: high speed
#ifdef ENABLE_SERIAL_PORT_TWO
void Init_Serial_Port_Two(void)
// SPBRG2 = BAUD_9600; // baud rate generator register [251]
SPBRG2 = SPBRG_VAL_2; // defined in hardware.h
#ifdef USART2_USE_BRGH_LOW
TXSTA2bits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
TXSTA2bits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
in the hardware set up routines...
// Define system xtal/clock frequency
#define CLOCK_FREQ (40000000) // Frequency in Hz
#if defined(__18CXX) // All PIC18 processors
#include <p18cxxx.h>
#define INSTR_FREQ (CLOCK_FREQ/4) // PIC18 clock divider
#else
#error Unknown processor or processor not defined
#endif
// Set up serial port(s) baud rate
#define BAUD_RATE_1 (38400) // Serial port 1, bps
#define BAUD_RATE_2 (38400) // Serial Port 2, bps
// set as needed...
//#define USART1_USE_BRGH_LOW // for most lower baud rates
//#define USART2_USE_BRGH_LOW // for most lower baud rates
#if defined(USART1_USE_BRGH_LOW)
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/64) - 1)
#else
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/16) - 1)
#endif
#if defined(USART2_USE_BRGH_LOW)
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/64) - 1)
#else
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/16) - 1)
#endif
#if ((SPBRG_VAL_1 > 255) || (SPBRG_VAL_2 > 255))
#error "Calculated SPBRG value is out of range for current CLOCK_FREQ."
#endif
Unread 04-01-2008, 14:19
Code Monkey Code Monkey is offline
FRC #1622
Code Monkey is an unknown quantity at this point
Talking Re: New C18 3.0+ Compatible FRC Code
To be clear, without Kevin this would be miserable. Team 1622 is massively
in your debt. Thank you.
For those who have not already installed the MCC upgrade, make sure you put it in the same directory with the upgraded MPLAB 8.0. Otherwise the linker can't find the libraries. I know by the trying it the wrong way.
Unread 04-01-2008, 19:23
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Rookie team 2605 will be using your code, it is structured in a way that makes more sense, I have not gone through it all the way yet, but so far so good. BTW is there a better search tool in mplab than the just straight basic find? For my embedded systems work I am always using grep and regexps, so far mplab has been really disappointing.
Unread 04-01-2008, 21:16
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Comphappy,
The answer maybe Yes!
Try under the Project Menu > Find in Project Files.
Once you enter your keyword you'll be able to see the results in the output window under the find in files tab.
Double click on whatever you want to see and a new window will open with a pointer to your chosen element.
I hope this answers your question, as I'm not really sure as to what grep would deliver as a result.
Unread 04-01-2008, 22:01
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Thanks that is what I was looking for, still not very good, but better then what I had found. Grep is extreamly flexible long as you are willing to spend the time to learn how to use it correctly.
Unread 04-01-2008, 22:22
FRC #2429
Here's a snapshot of the latest build:
http://kevin.org/frc/ifi_frc_beta_3.zip
http://kevin.org/frc/ifi_frc_gyro_beta.zip (with integrated ADC and Gyro code)
-Kevin
Kevin Watson
http://kevin.org
Unread 04-01-2008, 22:33
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Kevin,
Is there any change log? So we can keep track of what's bew in beta 3? Other than, of course, the ADC and gyro in that version.
Thanks.
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
