Go to Post If that many teams could do it successfully every match this year I will eat my robot. - Jay O'Donnell [more]
Unread 26-12-2007, 03:36
Kevin Watson's Avatar
La Caņada High School
FRC #2429
New C18 3.0+ Compatible FRC Code
I've created C18 3.0+ compatible code and libraries for the IFI FRC robot controller. At this point the code is pretty solid and free of bugs. If interested, the code can be found here:
http://kevin.org/frc
Remember this is experimental code, so please do me (and everyone else who might use this code) a favor and let me know if you run into any bugs. Thanks.
1/6/08 Edit: You need MPLAB 7.21 or greater to use the 3.0+ compiler. You can download the latest version here:
http://www.microchip.com/stellent/id...&part=SW007002
The student and upgrade versions of C18 3.10 (don't use 3.15) are here:
http://www.microchip.com/stellent/id...&part=SW006011
-Kevin
Kevin Watson
http://kevin.org
Unread 26-12-2007, 06:59
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: New C18 3.0+ Compatible FRC Code
Kevin,
I like the layout....a lot cleaner than the present code template. Had a little problem compiling:
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_frc.c" -fo="ifi_frc.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\dev\ifi_frc_beta\ifi_frc.c:249:Warning [2002] unknown pragma 'tmpdata'
C:\dev\ifi_frc_beta\ifi_frc.c:250:Error [1020] unexpected input following 'interrupt'
C:\dev\ifi_frc_beta\ifi_frc.c:357:Warning [2002] unknown pragma 'tmpdata'
Suggestions?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 26-12-2007, 08:51
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
I do like the layout better than the code from years past. A little less cryptic in function definitions, and file names. Although I do not know what the Disable_spin(), Autonomous_Spin(), and Teleop_Spin() are and what they would be used for.
Are their equivalents be Process_Data_From_Local_IO() just split up into different places??
Also I do like the addition of the check of the state to reset the outputs. Shouldn't this stop situations where you can only get one autonomous run from each hard reset?
I cannot confirm or deny any bugs on a compile. I have neither mplab nor mcc18 and only have a mac
Unread 26-12-2007, 10:45
FRC #2429
Originally Posted by Jon236 View Post
Had a little problem compiling...
It's not backward compatible with the 2.4 compiler. I'll create a 2.4 friendly version if people like the layout. The update to 3.1 is available on Microchip's website:
http://ww1.microchip.com/downloads/e...-doc-v3_10.exe
-Kevin
Kevin Watson
http://kevin.org
Unread 26-12-2007, 11:00
FRC #2429
Originally Posted by Joohoo View Post
...I do not know what the Disable_spin(), Autonomous_Spin(), and Teleop_Spin() are and what they would be used for. Are their equivalents be Process_Data_From_Local_IO() just split up into different places??
Yes, you're correct.
...Also I do like the addition of the check of the state to reset the outputs. Shouldn't this stop situations where you can only get one autonomous run from each hard reset?
Shouldn't be a problem as long as the controller is sent to the disabled state first and you reinitialize your autonomous code. Perhaps I could provide a flag to let you know to initialize your code?
-Kevin
Kevin Watson
http://kevin.org
Unread 26-12-2007, 14:03
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Is there any advantage to using the 3.0+ compiler?
Unread 26-12-2007, 14:27
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Kevin,
I really like the structure of this code. It is MUCH cleaner and easier to follow. It will definitely help in teaching our newer programmers how to code specifically for FRC. I really like the use of the *_Spin functions. They make following and understanding the code and how it operates much easier, not only for new programmers, but also for relative Noobs to coding, like myself.
I see you are also taking advantage of the 3.0+ interrupt optimization capabilities. As we write ISR's will it be necessary to modify the way you are excluding the ".tmpdata"
"#pragma tmpdata low_isr_tmpdata
#pragma interruptlow Interrupt_Handler_Low nosave=section(".tmpdata")"
If I understood the included "C18 ISR.pdf", we should be fairly safe and not have to modify it at all, correct?
PS. I am really interested in making this code work with Vex if possible. I know this is a ways down the road, but it looks like it may just work. I'll keep you posted. I will wait to start down that road until the issues you pointed out are cleaned up first.
Unread 26-12-2007, 14:46
bagawk bagawk is offline
AKA: LeeP
FRC #0997 (Spartan Robotics)
bagawk is an unknown quantity at this point
Thanks Kevin! The code is much cleaner and better documented than what ifi gives. The interrupts setup will be a great help to a lot of teams I am sure.
BTW, I have an updated version of my makefile to build this code if anyone is interested.
http://team997.org/files/software/Makefile_ifi_frc
Unread 26-12-2007, 14:54
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Overall I really like to layout of the code. It looks a lot more intuitive than the IFI stuff.
I really like that the serial port, interrupts, timers, and PWMs, are already intgrated. That should save some time during the season.
The only issue I've got is the x_Spin functions. It seems to me that most of the code that I would run there would be the same regardless of the current mode. I believe that I would modify it to call just one function, and use the mode flags to change the few things that are different.
EDIT: I haven't compiled it yet, since I don't want to mess up my main dev box. Tonight I'm going to setup a VM with c18 3.15. I'll post if I have any issues then.
Eric Haskins KC9JVH
Unread 26-12-2007, 16:39
billbo911's Avatar
The more I read this code, the better I like it. I see you have included many of your "updated" functions as part of the base code. Thank you!!
I did note a couple things that may be a problem, but I am not certain because I am no expert when it comes to coding.
I noticed a couple "#include" statement for files that do not exist. For example, in "ifi_code.c" is a call to include "adc.h" and <delay.h>. I'm not clear on the differences when the "<xxxx>" is used, but it sure would be nice to have your "adc" code included.
Just my $.02
Unread 26-12-2007, 16:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The layout looks a lot more straightforward than the standard IFI. To address the concerns of those who would rather have a single Spin function, you always have the option of defining your own Default_Spin() function and calling it from each of the other Spin functions. I really think that choice comes down to six of one and a half dozen of the other. If you'd rather have a single spin function and switch inside of it on flags, you're duplicating the mode determining logic already defined in the main loop for the privilege of shoving all your spinning code into one large function. I don't think saving a function call to a Default_Spin() routine is really worth that hassle.
Unread 26-12-2007, 17:06
in between teams
AKA: Luke Van Oort
I'm sure I'm just being stupid or something like that, but whenever I try to open the workspace I get a "Unable to open the workspace because the format of the workspace file has changed" error followed by "A lock violation has occurred". I can open the individual *.c and *.h files just fine.
Anyway, I've only just started looking through this and it already looks awesome! I really like the timer setup and interrupt handling setup. Last year I did some interrupt and timer stuff and it could get rather confusing; this will be great for our new, inexperienced programmers to get into interrupts without quite as much trouble. It is almost like if you took the logical layout and ease of coding interrupts from WPIlib and combined them with the lower level control of IFI's code. Great work, Kevin!
Team 1219: 2009 - Mentor
Unread 26-12-2007, 20:29
AKA: Eric Haskins
I just setup a clean virtual machine with Windows XP Professional sp2. I ran Windows Update, installed MPLab 8.0, and installed C18 3.15 Student Edition.
Here are the errors I'm getting:
MPLAB C18 v3.15 (demo)
Copyright 1999-2005 Microchip Technology Inc.
Days remaining until demo becomes feature limited: 60
C:\Documents and Settings\Eric Haskins\Desktop\ifi_frc_beta\ifi_frc_beta\ifi_code .c:31:Error [1105] symbol 'ADC_VREFPLUS_VDD' has not been defined
C:\Documents and Settings\Eric Haskins\Desktop\ifi_frc_beta\ifi_frc_beta\ifi_code .c:31:Error [1105] symbol 'ADC_VREFMINUS_VSS' has not been defined
Halting build on first failure as requested.
BUILD FAILED: Wed Dec 26 19:25:06 2007
What did I forget?
EDIT: I moved it to a shallower directory, but it still returns that error.
EDIT: I uploaded a file with the output from the compiler.
Eric Haskins KC9JVH
Unread 26-12-2007, 20:50
billbo911's Avatar
What did I forget?
Honestly, I don't think you did anything wrong. I believe a file or two were left out of the zip. If you'll notice, at the top of ifi_code.c is a "#include adc.h", that file is not included in the .zip.
Unread 26-12-2007, 20:57
AKA: Eric Haskins
I believe that headers within <>s are found in "c:\mcc18\h" by default. If you look adc.h, delays.h, and stdio.h, are all located there.
Eric Haskins KC9JVH
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
