Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Unread 26-12-2007, 22:00
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
bobdahaxor is an unknown quantity at this point
Use of laptop on robot
Everything in me says this is against the rules, so someone please point it out to me or verify it is legal to do so! Thanks!
Unread 26-12-2007, 22:10
Re: Use of laptop on robot
Please read the section of the rules entitled "The Robot". As I recall, laptops are not explicitely banned on the robot itself, but they need to use the 12V power supply, not their own battery, which makes them illegal. (I don't have the rules handy, so I can't check easily.)
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
<R51> The total cost of all non-Kit Of Parts items must not exceed $3,500.00 USD. No individual item shall have a value of over $400.00. The total cost of components purchased in bulk may exceed $400.00 USD as long as the cost of an individual component does not exceed $400.00.
That's retail. So at the least it's only legal if you can find a retail laptop for under $400. EricH has a good point as well. And then there's the question of whether you count then fans and hard-drive motors as extra motors and....
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Depends on this years rules.
You would have to find a way to power it. Extra batteries are never allowed.
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
The only problem I would see with doing this is that it must be powered by the robot battery, which means that once the match starts, then you can start it up. By the time windows will start, your match will be over.
I win! XD
Unread 26-12-2007, 22:39
Billfred's Avatar
Billfred Billfred is offline
I can't put my fingers on the Q&A at the moment (if they're even up still), but I recall the GDC historically deeming hard drives illegal as they use non-kit motors.
Unread 26-12-2007, 22:43
IndySam's Avatar
but you could use a SS drive now.
Unread 26-12-2007, 23:44
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Actually, a laptop would qualify as ac ustom circuit. I doesn't have to be routed through a victor or spike because it isn't a solonoid or electromechanical device like a motor. The rules say that a custom circuit just needs to be on a 30 amp breaker with your option of smaller fuses on the line running to it. So technically, the laptop would have power as soon as you set up your robot on the field. By the time the announcer finished stating the team names it would probably be booted(except if you are using windoze vista ).
My team is using a Linux coprocessor this year. While we aren't using a laptop necessarily (screen+keyboard=too much weight) we are using full computer. We took a mini-itx motherboard and set it up to run off the robot battery. The only violations we managed to find (and I personally think would probably go unnoticed when our robot is being inspected) were the system clock battery and the cooling fans. We can get by without the system clock battery because we don't really need to keep time. I'm not sure if this is an actual rule or not, but some of my teammates said that there is a rule that states that all fans used on the bot must be the ones in the KOP. In that case, we can just replace the cpu cooling fan with a muffin fan from the KOP because it uses the same power. As to the issue of hard drives, we are using a solid state flash disk. Other than power, I think you could put a laptop on the bot if you want to.
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Unread 26-12-2007, 23:45
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
you could do it with last years rules if you used a Solid State hard drive and took out the stock fan and used a KOP one (not to hard seeing that mines cooked by a cooling pad since the internal fan died. you could put a lightweight linux distro on it and hibernate it before a match to make it book quickly. not sure it would be worth the trouble though since most laptops dont have allot of IO but i may be useful for image recognition or tracking of objects etc
...forest
Unread 26-12-2007, 23:48
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Or build a 19v(thats what most laptops seem to use) DC-DC step up converter, and keep the battery on RIGHT until your about to get onto the field, then remove it to make it legit. In all practicality, laptops are better suited to transmit something over a analog input, and reccive stuff from the dashboard port.
Unread 27-12-2007, 00:03
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ASUS eee PC: $349-$399, no fans, solid state hard drive, runs linux or XP, and weighs under 2 lbs.
Zan Hecht
Unread 27-12-2007, 00:06
So, of course, you'll make sure to solve all these problems before you even consider putting this on your robot....
Annnyways. A good Q&A to pose to the poor GDC early on would be how to account for such a system. Do you price the RAM, processor, drive, power supply, etc separately if you buy the separately and assemble it yourself? What if you buy it as a system? What if you buy a system but partially disassemble it? This obviously similarly applies to mechanical systems, of course, but the PC system got me thinking about it.
Unread 27-12-2007, 01:36
AKA: Don
Thats a good point. But I suppose if a pc system did get expensive enough you could individually price each component. We got ours on ebay for less than $100 and it included the ram and processor.
-Don
Team 548:
Unread 27-12-2007, 02:14
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
just out of curiosity why do you want to put a laptop on your robot?
I could understand for dashboard stuff on the o/i but the robot? (unless you are using it for some crazy powerful camera tracking)
Unread 27-12-2007, 08:39
2007 Q&A
8.3 Robot Rules - Hard drive on robot?
http://forums.usfirst.org/showthread.php?t=1095
Q: Are we allowed to have a hard drive on the robot for processing information? Or would we have to use a storage device that has no motor?
A: No, as a disk drive would include an additional motor and would therefore violate Rule <R46>. Solid state storage devices may be used, as long as they are used in compliance with all rules regarding custom circuits.
FIRSTSearch 2007
Laptop Controlled VEX robot John Gutmann Technical Discussion 0 11-04-2007 00:51
Can we use 2006 Robot Controller? steve d Electrical 7 14-02-2007 16:46
Can we use stepper motors on robot?? Leo 1529 Motors 4 06-02-2006 16:51
is fiberglass legal to use on a first robot? Skute327 Technical Discussion 26 29-09-2005 13:26
Can we use sirens on the robot? intx13 Rules/Strategy 14 18-01-2004 19:17
