Go to Post Please teams I implore you obey the no saving seats rule. Or at least be very friendly in inviting people to sit with you. - IndySam [more]
  #36   Spotlight this post!
Unread 27-12-2007, 15:28
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Gear Tooth Sensor
Ah! I see what you are saying... you kill power but the bot still rolls. Well ok you have to "remember" which direction you were rolling and allow the bot to come to a complete stop... before changing direction with a single GTS. Yes in that case Quad is preferable.
But probably not a problem with something like positioning an arm.
In any case... this is still a "dead reckoning" scheme so it's an approximation anyway. (If it were easy it wouldn't be worth doing. )
In an aside... to obtain Quad with GTS... one suggestion has been that :
1) using a gear with an odd number of teeth.
2) using two GTS
3) IF you carefully position them at 90 degrees to the gear center, you get a 90 degree phase shift and can treat them as an A B phased encoder.
I haven't done the math on this but it seems plausible.
Steve
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear tooth sensor issues Nine9cracker Electrical 2 17-01-2006 02:37
