Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 28-12-2007, 10:06
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: An Exercise: Pros and Cons Of A Water Game
BTW, I thinks it's Great that Falcon Robotics has tackled the task of FIRSTing an underwater robotics competition. If they were closer to MD I'd want to send a team.
The more I thought about "problems" with fielding a team for this sort of competition, I realized that an essential isse is that it may be hard to find somewhere to test your robot.
Granted, not many FRC teams have full size playing fields for practice, but at least you can test the drive system anywhere. For a ROV contest, you need a reasonable quantity of water. If your school doesn't have a pool, or (more likely) they won't let you use it for robots, then what's the next option?
Sure you can use a 55 Gallon barrel of water..... but seriously, it's hard to build excitement that way
Once agian, I'm not trying to discourage the idea, I'm just highlighting the key problems, in order that they can be addressed. We don't have a school pool in my area, and even though I'm on a small lake, it would be difficult to use for testing purposes (especially when it's frozen
Luckilly, I've found a firm that will build me a test tank, and I have somewhere to put it. I'm am hugely lucky in this regard.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 28-12-2007, 10:26
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
The systems I am referring to does not come complete and are not very accurate. You can use a set of accelerometers that FIRST has provided in the past, I don't recall the make an model, maybe someone else can. They do not however account for drift as I mentioned before. Right now we are working on using two digital compasses that Davantech makes
http://www.acroname.com/robotics/par...7-COMPASS.html
and we can read the data coming from them, the next step is integrating it into the robot controller. It may not be as accurate, but we are not traveling long distances and we have visual feedback from the video cameras as well to make corrections. We will post our findings when we are done working on it. They cost 60 dollars each. The best thing is to use a Doppler Velocity Logger but that is 12 grand. Another compromise is
http://www.cloudcaptech.com/crista_imu.shtm
I think it is about $1500 - $2000 about he price of a IFI control unit
Maybe if FIRST buys lots of these the price might drop?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 28-12-2007, 10:31
AKA: Ledge
The tank is the biggest issue. Either the venue has to change or you can buy a lot of above ground pools. Very expensive for just one year. This is a problem for someone at a higher pay grade than mine.
Unread 28-12-2007, 10:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Maybe that's why the underwater competition works so well in Arizona, of all places....if you live in Arizona, and you don't have a swimming pool in your back yard, your neighbor does!
Unread 28-12-2007, 14:00
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
con:
it would be hard to make a water tight field
Unread 28-12-2007, 15:54
talltree357's Avatar
talltree357 talltree357 is offline
AKA: Joe Gro
None #0357 (Royal Assault)
talltree357 is a jewel in the roughtalltree357 is a jewel in the roughtalltree357 is a jewel in the rough
Send a message via AIM to talltree357
Pro: A new, and completely different challenge for students to take part in. Allowing them to explore new concepts, and areas of study.
Con: The problem with a water game is unless you build the tank out of translucent material, it is very unappealing for the crowd. Thus it makes it much worse when you are showing the field to potential sponsors and the crowd itself.
Unread 28-12-2007, 18:03
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Originally Posted by Cory View Post
pros: none
I truly don't understand the fascination with a water game. It doesn't interest me at all.
ditto...
there is a water game called MATE.... people who want a water game should ask their team leads to drop out of FIRST for a year, and do MATE...than choose if they want to do one or the other or even both in the future... that should get water out of many people's systems.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 28-12-2007, 21:26
AKA: Ledge
Originally Posted by Pavan View Post
ditto...
There is also NURC put on by APASE
www.h2orobots.org
We have both land and water based robots for 5 years....can't get it out of our system. We did MATE for three of them, couldn't get enough so we made our own. Let me know if you have a cure........
Unread 29-12-2007, 13:49
Squab's Avatar
Squab Squab is offline
The Afroman
AKA: josh
FRC #1507 (WARLOCKS)
Team Role: Student
Squab is an unknown quantity at this point
Pros: no one will be thirsty
Cons: water and electronics dont go together that well
Unread 29-12-2007, 14:11
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
The Pros of such a game would be increased thinking, and more creative designs.
The cons are obvious. One of which would be the transformation of all the regional arenas into "water arenas". I don't think that would go over to well with DU replacing their Ice Ring with water.
Unread 29-12-2007, 15:35
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Pro: No longer driving, you're flying: three dimensional field
Can be cheap: http://nventivity.com/ROVIAB.html
Con: Finding a team to compete against
Unread 29-12-2007, 17:12
AKA: Ledge
Maybe we can use Sea world for a venue!
Unread 29-12-2007, 17:19
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
That would be awesome!
I've never been there and we get to show off robots that swim. And the robots might later be able to swim with animals too. (This is for all you enviromentalists out there.)
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 29-12-2007, 19:14
Onward through the fog.
Thank you for your posts with your pros and cons!
I tend to try to make order out of chaos. When posts are made about a water game, the suggestion is made but there is usually nothing of any substance to follow that suggestion. It has happened enough times that I wanted to try to get a better grasp of it. My initial thinking is that one cannot move from the land robots to water robots just like that. Experience and opinions have been shared in this thread and I think they have been beneficial in helping us understand the similarities and the differences regarding a water game.
One area that has not been talked about and I wonder about is suppliers. Would that change? If yes, how would that impact? What are those pros and cons as we know FIRST now?
Yes, there are other programs as has been discussed in this thread. What I would like to understand is that if a water game can be done, I don't think it is just that simple. When one makes a suggestion, he/she should try to look at the whole picture as much as he/she can see and then research and learn more about it. I think it goes further than a venue change.
~ Helen Keller
(1880-1968)
Unread 29-12-2007, 19:18
ervtech's Avatar
ervtech ervtech is offline
AKA: Robert Ervin
FRC #1218 (CHASS)
Team Role: Operator
ervtech is an unknown quantity at this point
well for a practice field, you can always use a pool... for the warmer states thats easy, but for the colder states there are plenty of indoor pools around
6WD Pros and Cons ChuckDickerson General Forum 59 13-01-2008 02:20
Pros and Cons of Using Pneumatics Joe_Widen Pneumatics 22 30-06-2006 10:16
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
