Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 28-12-2007, 14:00
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
Yes, this was considered, but I have a very small bias toward keeping the number of source files down to a minimum. Since most new teams probably won't touch the Autonomous( ) or Disabled( ) functions, adding four more source files would make the learning curve a little more steep. With that said, if we can reach some kind of consensus on this or any other aspect of the code, I'd be more than happy to modify the code to meet the needs of the community (which is one of the reasons I started this conversation).
-Kevin
What is your stance on pre compiling your drivers and back end code into a library? The source would be available to read, but you could cut out some of the mess in the source tree.
Although, on second thought, this may be a pain to maintain.
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
