Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 29-12-2007, 00:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Serial PWM motor controller
It looks like minimum power dissipation on a P3 is around 20W. Max is 27W. Additional draw from the drives, etc would probably end up around 20W, so figure 40W to 47W from the PC, and just assume 100% efficiency for the power supply. That's about 4A draw, at a minimum, assuming a very plain video card. If you're using a car battery, they have a reserve capacity rating that says how long they'll last with a 25A load. 80 minutes is typical, so you'd get something like 8 hours out of that on a good day. Of course real world loads will be a good bit higher when you're running motors, etc. If you're really looking for long runtimes, I'd invest in a deep-cycle or SLA battery, as those are designed for lower draw levels and more capacity. Car batteries are primarily design to push a very large amount of current for less than a minute without significantly shortening the battery's life.
No PWM from controller ctshirk7 Control System 10 27-01-2006 18:55
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
25 FT SERIAL CABLES (controller tether) sanddrag General Forum 10 06-09-2002 20:29
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
