Go to Post Dave, you're going to have quite the motor pool on Mars. :D - skimoose [more]
Unread 29-12-2007, 15:02
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Serial PWM motor controller
Originally Posted by smartkid View Post
- I'd like to be able to make something, perhaps a small LCD screen that could tell me the amount of charge left in the battery. So that I never drain it all the way and so that when it's charging we know when it's done. I believe the drop in voltage is how you can tell the amount of charge left? Like when the Vex controllers show voltage on the little LCD.
-Smartkid
We'll I don't know about using a full fledged LCD, although that would be cool... and my encouragement if you decide to try. But, you might want to look into a Digital Panel Meter, or a regular panel meter. They are a simple solution giving you an idea of how much charge you have left.
All Electronics has some pretty affordable ones. In fact we used one on our FRC robot last year. Ours was the only one that had one, and the engineer who inspected our robot kind of liked it.
www.allelectronics.com
No PWM from controller ctshirk7 Control System 10 27-01-2006 18:55
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
25 FT SERIAL CABLES (controller tether) sanddrag General Forum 10 06-09-2002 20:29
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
