Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
  #31   Spotlight this post!
Unread 28-12-2007, 03:44
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Tom Bottiglieri View Post
I can't decide on whether or not I will split off the teleop, autonomous, and disable functions to their own files. I feel like user_code.c will be a bit cluttered and may be overwhelming for new student programmers.
Personally, I advocate doing this. I think keeping the teleop and autonomous sections separate is beneficial. If you have multiple programmers, it makes it easier for different people to work on different sections.
Additionally, I strongly advocate that everyone add a "robot.c/robot.h" that has all the robot functionality. This should be the only place that directly sets any PWM value. It would have functions like robot_drive(speed, turn_rate, gear) and robot_set_arm_position(height). These functions would be called from both the teleop and autonomous functions. Then, when you change your robot, swap motors around, change a pneumatic gear shifter to a servo gear shifter, bend a pin on the RC, etc, you only have one location where you need to make code changes.
Basically the robot.c/h file presents the robot conceptually to the rest of the code. The autonomous and teleop functions can deal with the logic, like "the robot drives forward X distance, and then turns 90 degrees", and the robot.c/h functions can translate that into "set PWM01=255, and PWM02=0".
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
  #32   Spotlight this post!
Unread 28-12-2007, 13:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Thoughts? Kevin, any reason you did not pursue something like this?
Yes, this was considered, but I have a very small bias toward keeping the number of source files down to a minimum. Since most new teams probably won't touch the Autonomous( ) or Disabled( ) functions, adding four more source files would make the learning curve a little more steep. With that said, if we can reach some kind of consensus on this or any other aspect of the code, I'd be more than happy to modify the code to meet the needs of the community (which is one of the reasons I started this conversation).
-Kevin
Kevin Watson
http://kevin.org
  #33   Spotlight this post!
Unread 28-12-2007, 14:00
-Kevin
What is your stance on pre compiling your drivers and back end code into a library? The source would be available to read, but you could cut out some of the mess in the source tree.
Although, on second thought, this may be a pain to maintain.
  #34   Spotlight this post!
Unread 28-12-2007, 14:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by billbo911 View Post
OK, another noob question.
I installed a clean version of MPLAB the "upgraded" it with the file from the link Kevin provided.
I can't get it to open Kevin's ifi_frc.mcp. So, after using the Project wizard to create a new project, it will compile correctly without errors. Well, that's partially true, I had to comment out a printf statement in user_code.c.
Now the output window keeps spitting this out:
"Error: Bad magic number in COFF file "C:\TEMP\C18 3.0beta\ifi_frc_beta\ifi_code.o".
So, what is that telling me? What is a "magic number"?
Just a bump. Still looking for the answer.
  #35   Spotlight this post!
Unread 28-12-2007, 14:24
FRC #2429
What version of MPLAB are you using? If it's anything less than 7.4 (I think), it won't work with the new compiler.
-Kevin
Kevin Watson
http://kevin.org
  #36   Spotlight this post!
Unread 28-12-2007, 14:38
FRC #2429
No, it's a good idea and one I'm entertaining (e.g., I already have a version of ifi_frc_xxxx.lib with the serial port code included).
My interest right now is to make sure that the CD programmer community is okay with the architecture and, hopefully, will spend some time finding any bugs I've introduced. Once that's done, I'll have a look at simplifying the source tree.
Speaking of bugs, does anyone have any code which will consistantly cause the 8.3 volt problem? I have a theory I'd like to test out, but haven't been able to reproduce the bug.
-Kevin
Kevin Watson
http://kevin.org
  #37   Spotlight this post!
Unread 28-12-2007, 15:02
billbo911's Avatar
-Kevin
From my original post,
I installed a clean version of MPLAB then "upgraded" it with the file from the link Kevin provided.I can't get it to open Kevin's ifi_frc.mcp....Now the output window keeps spitting this out:
So, I thought it was 8.10, but now that I think about it, I originally installed 7.4 and the upgrade is only for C18, so I might still be at MPLAB 7.4, and C18 is 3.1. I'll verify when I return home this evening. Thanks Kevin!
  #38   Spotlight this post!
Unread 28-12-2007, 15:54
FRC #2429
From the C18 3.10 release notes: "MPLAB C18 v3.00 and later will not be compatible with versions of the MPLAB IDE prior to v7.21".
-Kevin
Kevin Watson
http://kevin.org
  #39   Spotlight this post!
Unread 28-12-2007, 20:10
billbo911's Avatar
Yep, you nailed it Kevin.
I had installed MPLAB 7.20, added C18 2.x then upgraded C18 to 3.10.
So, now that I have reinstalled MPLAB 8.0 with C18 3.10, it works like a champ! It loads and builds your project first time, every time.
Now I'm off to try and see if I can actually do something with it.
  #40   Spotlight this post!
Unread 28-12-2007, 20:31
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Thanks immensely. I use C18 3.10 all the time, and its a pain to have to maintain two seperate development toolchains for general purpose and FRC specific code. It's great not having to go searching for that ancient C-BOT compiler disk whenever I need to set up a box for FRC code, when I can get the most recent MPLAB IDE and C18 from the microchip website.
  #41   Spotlight this post!
Unread 28-12-2007, 23:05
AKA: Dr. Brooks
no team (WRRF)
-Kevin
We don't have a program that could run on a bare controller, but I believe that we still have our 2006 robot fully together (currently with a 2005 controller) and could put the 2006 controller and program back in it without much effort. I would not say that it "consistently" hit the the 8.3 volt bug, but it most certainly hit the problem frequently. If you have a patch in mind we would be willing to try it out during the build period. It would be really nice to fix that bug. We have sworn off using interrupts (in our own code) on the 8722 based controllers until the problem is addressed.
Eugene
  #42   Spotlight this post!
Unread 29-12-2007, 00:57
FRC #2429
Eugene
Thanks. I'd be happy if I could just get a .map or .lst file of a build that exhibited the problem.
-Kevin
Kevin Watson
http://kevin.org
  #43   Spotlight this post!
Unread 29-12-2007, 01:33
AKA: Dr. Brooks
no team (WRRF)
-Kevin
Kevin,
I have sent you a web link to download a zipped example via a private message.
Eugene
  #44   Spotlight this post!
Unread 29-12-2007, 04:15
FRC #2429
Kevin,
Eugene
I got the code. Thanks.
-Kevin
Kevin Watson
http://kevin.org
  #45   Spotlight this post!
Unread 29-12-2007, 18:03
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
I noticed that you did not add the:
#pragma tmpdata low_isr_tmpdata
#pragma tmpdata
in the serial interrupts handlers?? but you did so in the timer.c and interrupts.c handlers??
is this an oversight??
thanks...
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
