Go to Post but you can rest assured: I have restored the balance by letting the GDC know that I know that they know that you know they have a pattern. -Leav - Leav [more]
Unread 28-12-2007, 22:51
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
pic: Front / Rear bearing saddles rev 2
Unread 28-12-2007, 22:52
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Re: pic: Front / Rear bearing saddles rev 2
That looks fairly similar to a globe motor mount I made last year. Those little holes were a real pain in the drain to line up.
Unread 29-12-2007, 23:47
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
nice!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 30-12-2007, 06:30
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
So are you machining that out of a solid piece of aluminum or are you just going to bend some 5052 or 3003?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 30-12-2007, 13:06
I am open to suggestions and we in fact are very much dependant upon a machine shop to help us with this project. I don't have any experience bending anything other than sheet metal. Does one need a hydraulic bender to make the 90 degree bends in the 5/16" aluminum?
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 30-12-2007, 13:08
Those little holes are actually tapped for a machine screw and washer. The intent is that they will capture the flanged ball bearing. I uploaded the wrong file. The final version has a 0.500 inch fillet to round off the corners on the bottom.
APS
Founder FRC 499
Unread 30-12-2007, 13:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Absolutely. I've never bent anything near that thick, but there's no way you're going to be able to do it with a hand break.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-12-2007, 16:38
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
You aren't really going to be able to bend 5/16" thick aluminum with a radius small enough to satisfy your demands. Generally when working with sheet metal, the bend radius should be at least the thickness of the material, and can actually be a lot greater depending on the alloy.
Also, what types of machines would your machine shop be able to provide?
The types of machines they have can greatly affect how you design your parts; if they had a sheet metal turret/punch or a waterjet, you could design that entire bracket to size out of 0.1875" or 0.125" aluminum and have it bent to 90º. Then to increase the thickness needed for a flush bearing fit, you can just make a second small plate that goes around the bearing hole and is bolted to the main bracket.
But if they have conventional milling machines, it's hard to find extruded aluminum in fractional sizes above about 2.00", so they'd have to mill it out of a solid block of aluminum, which would drive costs up if it's not being donated to your team.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-12-2007, 17:23
run the trap!!!
Team Role: Human Player
You could always do it with a blow torch , It can be hard to get it accurate but it's a lot of fun. So long as you make it hug the frame member tight, you can then go back and cut the bearing holes to fit.
-Philip J. Fry
Unread 30-12-2007, 18:15
Now that I have my design,
To make machining easier, what if I made this a three piece bolt together assembly? It would have two identical side plates and then the top piece. Maybe four tapped holes for #8 or #10 machine screws or clearance holes for the same with nylon lock nuts at the end of 2" bolts... I wouldn't know how to calculate the bolt strength needed to deal with the loads.
APS
Founder FRC 499
Unread 30-12-2007, 18:40
artdutra04's Avatar
Does your machine shop have welding capabilities?
When my father and myself were working on the Mountain Dewbot, we machined a bunch of brackets similar to the one in this thread out of 0.25" aluminum plate, tapped and threaded for 6-32 hardware to hold it square, and had the seams welded. As long as you bevel the edges (after tapping) where they'll weld, you'll get good penetration and have a strong joint.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-12-2007, 18:56
I like this idea. Since I don't have clearance for welded material on the inside seams you are suggesting that we chamfer the edges that will butt together so that the weld will have a void to fill and hold it together.
APS
Founder FRC 499
Unread 30-12-2007, 21:24
Cory's Avatar
AKA: Cory McBride
Make sure that if you make it out of more than one piece, you put the motor and bearings in first, and align everything as it should be prior to welding.
Screws are not good for holding locations. You will have enough play in your pieces that if you don't get everything lined up, you could easily end up with your bores not being concentric after welding.
2001-2004: Team 100
Unread 30-12-2007, 21:31
artdutra04's Avatar
Yes. The chamsfer will help the weld penetrate deeper into the material for a stronger hold, and it will end up being nearly flush. (Since the edges of the 80/20 extrusion are rounded, there is a slight tolerance there anyway. )
Here's a picture of the brackets from the Dewbot that I mentioned in my previous post.
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-12-2007, 10:57
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Another alternative is to weld the three pieces first and then do all your machining. This allows any warpage or misalignment to be machinined out of the bracket. Decide on your main datum plane and dimension off this for the machining.
Andy Brockway
Team 716, The Who'sCTEKS
pic: Rear view of our 07 'bot Cody Carey Robot Showcase 7 16-02-2007 12:29
pic: Team 207's Rear drivetrain Metalcrafters Robot Showcase 2 21-02-2006 22:51
pic: 237 rear window sticker Jay H 237 Extra Discussion 2 28-02-2005 12:06
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
