Thread Tools |
Rating:
Display Modes |
#13
Re: New C18 3.0+ Compatible FRC Code
Treat the digital I/O as instantaneous. It's faster than the execution speed of the program instructions. What you read from an input pin is the state of the pin at that moment. What you write to an output pin takes effect immediately. There are measurable (but trivial) delays, but unlike PWM and relay outputs, there's no interprocessor software communication in the way to slow things down.
| Does the camera code suits to all versions of MPLAB and C18? | razer | Programming | 3 | 04-01-2007 14:50 |
| Trying to follow C18 interrupt context code... | dcbrown | Programming | 5 | 21-12-2006 09:01 |
| Error w/ FRC code | JamesBrown | Programming | 2 | 08-01-2005 16:17 |
| Programming code Fix FRC | Ferazel2001 | Programming | 6 | 08-02-2004 02:46 |
| FRC default code | hedgehogger | Programming | 2 | 21-01-2004 18:41 |
