Go to Post Someday, when I grow up, I want to join the GDC so I can make people go crazy, and then release hints that get people even crazier. - unionylibertad [more]
Unread 13-11-2007, 20:30
Kilroy0846 Kilroy0846 is offline
FRC #2139
Kilroy0846 is an unknown quantity at this point
IFI Traction Wheel stationary?
Ok, heres my question. I have an IFI Traction wheel and I want it to be stationary on the axle. So when i turn the axle the wheel turns with it. Any ideas on how to solve this? Will a pressure fit work with IFI traction wheels?
Also, does anyone know the dimensions of the protrusion of the IFI sprockets? From wheel hub to end of the hardware.
Thanks
Unread 13-11-2007, 20:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: IFI Traction Wheel stationary?
The IFI Traction Wheels are designed to be run on a "dead axle". They're furnished with bearings on each side of the hub for this purpose, so the hole in the sheet metal is 1.125" or so. They're not designed for a press fit and I doubt you'd have much success with such a scheme if you were to manage it.
If you'd like for the wheel to be on a "live axle" -- turned by a key in a keyway, for example -- I'd recommend that you purchase either the AndyMark Key Hub or their Hex Hub. These bolt onto the IFI wheels using the same hole pattern they provide for attaching sprockets and fit through the existing bearing openings easily.
The overall width of the wheels is about .5" larger than their spec'd size -- so 1" wheels are 1.5", etc. There are CAD models of all of the wheels available on their website at ifirobotics.com
--Madison--
...down at the Ozdust!
Unread 13-11-2007, 22:07
FRC #2139
Thank you very much. You have no idea how much that helped me.
Now where do I find a hex axle?
Unread 13-11-2007, 22:21
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
You can buy 1/2" hexagonal steel stock and machine an axle out of it. Try looking for a local metal distributor, or if you don't mind paying a premium you can order it from McMaster-Carr (search www.mcmaster.com for "steel hex stock").
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 13-11-2007, 22:30
AdamHeard's Avatar
Lead Mentor
I know this is random, but I just bought some steel hex stock from mcmaster... and for them, it is incredibly cheap! $10 for a 6' is pretty good with their reputation. It also arrived the very next day.
And to backup what others have said, the AM hubs are the way to go. You really can't beat that price and quality.
Do you have a lathe? If not, it may be difficult to get the axle in a bearing as it won't be round. I know some teams have put the hex directly in a bearing (217?), while others made a part that is round on the outside, and has the hex on the inside to seat in bearing (195?).
IF you don't have a lathe, you're probably better off going with the keyed shaft.
Unread 14-11-2007, 14:07
FRC #2139
I do have a lathe so it will make things easier.
Correct me if I am wrong but:
If you machine a 1/2" hex axle down so that it is completely round it will be much smaller than 1/2". So would a 3/8" inner diameter bearing be in order?
Unread 14-11-2007, 14:15
Circuit Breaker
Actually, when you say that a hex axle is 1/2", it means that it measures 1/2" between opposite faces, not opposite corners. So you could indeed turn down a 1/2" hex shaft to fit in a 1/2" bearing.
Patrick Fairbank
patfairbank.com
Unread 14-11-2007, 23:19
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
if you do end up machining your axles out of 1/2" hex, machine it as little as possible. it is very difficult to cut a long, precise diameter in steel hex. One of the transmissions I did earlier required a 3" long section of 1/2" hex cut down to round, it took quite a while to get the lathe cutting it to proper tolerance the whole length. Although our tolerance was pretty tight... its still a pain. keep it simple.
Unread 31-12-2007, 15:50
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Do any teams use aluminum hex shaft or is it always steel?
If steel is always used have teams drilled the shafts to save weight?
I hate the thought of the weight of that steel.
Unread 31-12-2007, 15:54
in between teams
AKA: Luke Van Oort
254/968 used aluminum shafts (albeit of a very strong alloy, either 7075 or 7068, I forget) in 2007 and, I believe, 2006.
Team 1219: 2009 - Mentor
Unread 31-12-2007, 16:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
we use 7075 for all our shafts (We had one this year out of 7068, but it had a gear hobbed onto the shaft itself). We use round stock and then mill the flats for the hex onto it, though.
We used a 2024 hex shaft for our spool to lift our elevator this year. Wouldn't suggest it for a driveshaft or anything under a ton of load, but it worked well for the application we used it.
2001-2004: Team 100
2006-Present: Team 254
IFI traction wheels rachal Technical Discussion 10 17-04-2007 22:01
IFI Traction Wheels V2 Testing Results Holtzman Technical Discussion 15 14-01-2007 23:28
IFI Traction Wheels chris31 Technical Discussion 4 23-12-2006 09:25
Reducing wheel traction dude__hi General Forum 18 29-03-2004 18:43
WHEEL TRACTION--PLEASE RESPOND archiver 2001 7 24-06-2002 00:36
