Go to Post GP may not be as common as we would like out in the "real world" but Ladies and Gentlemen it is out there. - Jay H 237 [more]
  #61   Spotlight this post!
Unread 31-12-2007, 13:41
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: New C18 3.0+ Compatible FRC Code
We(1103) willl be using this code. So far it looks good.
Eric Haskins KC9JVH
  #62   Spotlight this post!
Unread 31-12-2007, 14:23
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Originally Posted by Kevin Watson View Post
The linker won't create the section if no temp storage is needed. Try enabling one of the interrupts and put this code in the interrupt service routine:
int a = 2;
int b = 3;
int c = 4;
int d;
d = (a + b + c) - (c + a);
Compile and then look at the .map file.
-Kevin
Well in ver 3.10 of the compiler the .map file will NOT show an entry if there is no storage needed, but 3.15 will show a null entry. (as it should)
  #63   Spotlight this post!
Unread 31-12-2007, 17:31
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Hi Kevin.
Your new structure makes a lot more sense. I never liked the way the old code fell into the "autonomous" pit and never came out.
I installed MPLAB8 and upgraded to cc18 3.1. Other than the typical include/lib path issues asociated with any upgrade, your new code built just fine.
My own personal preference is to use more, smaller files, so my vote would be to split the auto and disabled modes out into sepparate files. I beleive that this would actually make it easier for teams not addressing these modes because they wouldn't have to keep scrolling arround the empty functions.
If you are lucky to have more than one programmer on the team, it does enable the "Autonomous" mode programmer to work somewhat independantly of the "teleop" programmer. Last year I also had c&h files for each of the four subsystems: UserIF, Drive, Manipulator and Vision, and assigned each subsystem to a student. It kept them out of each other's hair, and made it easier to see what had changed from version to version. Not much downside to extra files.
To Fill up the new files a bit, I would also vote for including the init_ functions. So, each of the mode files would have an init, spin and run function.
I also agree with the recomendation for teams to have a robot.h and robot.c file. It's the first thing I add to the standard ifi code. In my case this is where I put all my #defines for translating the cryptic I/O port names to robot functions, and code for enforcing various robot safety limits.
Team 1629 will definately be using your new code so I'm eager to see you fold all your other cool functions into this structure.
Phil.
A happy camper
Phil Malone
http://www.GEARSinc.org
  #64   Spotlight this post!
Unread 31-12-2007, 18:16
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Wow Kevin! I love it already. Everything is so well organized and everything is incorporated. This will be a really good tool for rookies as well as veteran teams . I will definitely be using this on our 2008 robot
  #65   Spotlight this post!
Unread 31-12-2007, 18:18
PhilBot's Avatar
AKA: Phil Malone
Just noticed this:
In your pwm_readme.txt file, you still reference Process_Data_From_Master_uP()
I guess this would now be: Teleop() and Autonomous(), although I see you make the call after these functions.
Phil.
Phil Malone
  #66   Spotlight this post!
Unread 31-12-2007, 19:32
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by PhilBot View Post
My own personal preference is to use more, smaller files, so my vote would be to split the auto and disabled modes out into sepparate files. I beleive that this would actually make it easier for teams not addressing these modes because they wouldn't have to keep scrolling arround the empty functions...
...To Fill up the new files a bit, I would also vote for including the init_ functions. So, each of the mode files would have an init, spin and run function.
Okay, I've implemented most of this. Is there really a need for a Disabled_Init( ) function?
-Kevin
Kevin Watson
http://kevin.org
  #67   Spotlight this post!
Unread 31-12-2007, 20:31
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
-Kevin
Good question!
One way to look at it is:
During Competition, the systems boot up in Disabled mode. It wouldn't be a bad place to do some of the system initializations, Pre-calibrations and OI input gathering. Gyros would love the fact that the bot is not moving and compressors aren't running.
On the other hand, it is a bit redundant considering the Initialize () routine already exists in user_code.c.
Honestly, I say, give it the boot. (Yes, pun intended )
  #68   Spotlight this post!
Unread 31-12-2007, 21:48
FRC #2429
Here is a snapshot of the current build:
http://kevin.org/frc/ifi_frc_beta_2.zip
-Kevin
Kevin Watson
http://kevin.org
  #69   Spotlight this post!
Unread 31-12-2007, 23:32
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
-Kevin
I would say it isn't. To my understanding (and the way I'd use it) the whole point of the disabled function is to initialize variables and do some setup. Hence, as far as I'm concerned, there's no need for an initializing function to the initializing function.
  #70   Spotlight this post!
Unread 01-01-2008, 00:10
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Checking our code for the last few years, we've had a Disabled_Init(), but mostly just used it for debugging. I think it's worth including, just for completeness. Similarly, each year we've had a Disabled_Spin() function[*], but it's always been empty. I think it's worth having all three functions (run, spin, init) in the framework for each mode.
[*] actually we called ours Disabled_Fast_Loop(); and the run function was Disabled_Slow_Loop(), but I think I like _Spin() and _Run() better.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
  #71   Spotlight this post!
Unread 01-01-2008, 00:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Well as I understand it, you're still getting valid data from the OI in Disabled mode and teams have used this fact to select auto modes before matches start. So presumably, you'd want a Disabled_Init() to re-initialize this variable to a default value if you had to do a restart. I can see uses for it, but mostly I think it should be left in just for consistency between the different modes.
  #72   Spotlight this post!
Unread 01-01-2008, 02:05
FRC #2429
Okay, it's easy enough to do, but disabled mode is nominally called three times each round (before autonomous, between autonomous and teleop, and after teleop). Should Disabled_Init( ) be called each time, or only the first time? If only the first time, under what conditions would the default_init_flag get reset?
-Kevin
Kevin Watson
http://kevin.org
  #73   Spotlight this post!
Unread 01-01-2008, 03:59
billbo911's Avatar
-Kevin
It should be called only the first time and then reset on power cycle or on RC reset.
Just my opinion.
  #74   Spotlight this post!
Unread 01-01-2008, 09:46
in between teams
AKA: Luke Van Oort
Just my opinion.
I would agree, but I am a person who likes to keep options open. With that goal in mind, I think it would be ideal to put the code that calls Disabled_Init() in an #ifdef conditional so a programmer can just quickly define/undefine something to change the behavior.
Team 1219: 2009 - Mentor
  #75   Spotlight this post!
Unread 01-01-2008, 10:03
PhilBot's Avatar
AKA: Phil Malone
-Kevin
In answer to your initial question about the need for a Disabled_Init() function... we also used this to trigger calibrating the Gyro. The actual callibration only occured if we stayed in disabled mode for several seconds.
We put in the delay because we didn't know if the system transitioned through Disabled between auto and teleop. Based on your post, I'm glad we took that precaution.
We also did it for code symetry more than anything else.... Yes, I also indent all my "=" signs the same amount. Just call me anal.
I think the Disabled_Init() is most usefull once before the match begins, so that would mean that you wouldn't really want it called between Auto and teleop.
I thought that it might also be good to call it on the transition from Teleop back into Disabled (to indicate that there might have been a field reset situation after a bad start) but the bot is in an unknown state at that time anyway (maybe on it's side) so you wouldn't necessarily want to make any callibration assumptions.
In the end I guess this function would only be called after reset, so it is a bit redundant with Initialize(). Although, if the function is resetting variables that only get used in disabled mode, then my anal side says that that's where they should be declared and initialized This is also what we did with our UserIF, Drive, Manipulator and VisionSystem variables. Declared and initialized in subsystem modules.
Thanks for even considering it
Phil.
Phil Malone
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
