Go to Post So, please, can't we all just live and let live? - Alexa Stott [more]
Unread 01-01-2008, 17:23
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: aux analog
Traditionally, on analog joysticks the AUX channel was tied to a throddle control, for flight simulators. In some other joysticks, its tied to the hat switch, such as the white(current?)KoP joysticks. If you make a custom controller, linear pots still work on this channel, so your really unlimited in what you can do with it.
OI LEDs on the 5v Aux ShadowFireGT Control System 7 25-02-2007 08:05
Aux 1 & 2 WGRAY Programming 1 12-02-2007 14:59
OI Aux Fault light red Vashts6583 Control System 1 25-01-2006 23:10
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
