Go to Post I know our driver is going to nats over the prom. I mean come on, who wouldnt? :D - karinka13 [more]
Unread 29-12-2007, 19:40
Re: PCB Programs?
Originally Posted by BQuennell View Post
In the past we've gone quite low-tech and just used Microsoft Paint to draw up the boards, we do have an etcher though so it makes life easy for the electronics guys and they just produce them on their own.
... Really? I HAVE TO SEE THIS.
I was joking about exactly this at work a week or two ago.
Please, details!
Unread 29-12-2007, 21:53
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: PCB Programs?
I think you could use Pad2Pad to generate your double-sided etch masks. It's easy to use, and has a pretty good autorouter.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 01-01-2008, 20:59
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
Re: PCB Programs?
Please, details!
Forgive me, I've been out of the shop since I graduated so I can't recall the name of the paper but it goes like this.
Someone designs the board in MS Paint, then prints the design out in a laser printer onto some special trace paper that you iron onto a clean board with like a clothes iron. It's really cool because the toner powder mixed with whats on that trace paper is able to avoid corrosion in an etcher so just toss it in and let the traces live, scrub off the toner and you have your board. MS Paint works great as well for this because you can zoom in to quite in depth and modify the circuit just about pixel by pixel.
The process isnt that bad to do really you can have the board done from printing to etching in about 25 minutes, but it does require an etcher which not everyone has. We're very lucky to have an electronics teacher from the High School be our lead mentor and let students use it.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Robot Controller 12v Power Spade Pulls Out PCB Dale(294engr] Control System 11 14-02-2007 13:32
Custom PCB bigqueue Technical Discussion 17 08-01-2002 21:54
