Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 01-01-2008, 20:09
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
pic: 2 speed tranny
Unread 01-01-2008, 20:13
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Re: pic: 2 speed tranny
why not big cim little cim combo?
Unread 01-01-2008, 20:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
A better question would be why use the big-cim little cim combo, if you don't need 2 small cims elsewhere?
2001-2004: Team 100
2006-Present: Team 254
Unread 01-01-2008, 20:21
in between teams
AKA: Luke Van Oort
Very nice, and very light! Is there a reason you switched to aluminum side plates and returned to bronze bushings?
Probably because that is significantly heavier, and a bit weaker.
Team 1219: 2009 - Mentor
Unread 01-01-2008, 20:29
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Its hard for me to judge from the angle, but it looks like you will not have much room for an output sprocket due to the encoder. I could just be look at a bad angle. Whats the gear ratios?
Unread 01-01-2008, 23:21
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Bronze bushings work well for shafts that have to slide as well as turn....
Unread 01-01-2008, 23:51
EricH EricH is online now
It does look that way. However, I'd say they aren't planning on having a sprocket directly attached to the output shaft. The encoder and shifter would get in the way except in a fairly narrow angle. Plus that's a pretty small sprocket. I'm going to guess that they use a coupler to a longer shaft that can either direct drive a wheel or connect to a sprocket.
My question is, are the side plates going to be hogged out to save weight? Those are some heavy trannies!
Unread 01-01-2008, 23:52
ADZDEBLICK's Avatar
The plastic plates we used last year flexed and allowed everything to become misaligned. In years past, everything spun on brass bushings except the motor combiner. On this design, everything is on bearings except the shaft for the smash shifting, however the gear cluster on that shaft has bearings inside of it.
The transmission is designed to be modular so we've put all the drive sprockets on the same shafts as the wheels (6wd).
http://www.flickr.com/photos/jdebner...7594547502324/
here's a pic of last years bot. you can kind of see how where the tranny links to the center axel.
.925:35 in low and 3:35 in high
Unread 01-01-2008, 23:55
ADZDEBLICK's Avatar
If needed yes, but I was under the impression that 3.32lbs per side was light.
Unread 02-01-2008, 00:07
Aren_Hill's Avatar
Build Nifty Things
Im with you on this one. 3.2lbs perside is quite light especially since your getting 2 speeds out of it. I do think you could get a bit more weight out of it though, maybe 3/16" sideplates?
A guy who likes robots.
Unread 02-01-2008, 00:08
Weight wise, you're carrying about 3 small CIM motors with the drive motors attached. Mind you, if you can get the rest of the robot to also fit in the weight budget, I'd rather have the weight in the trannies where it's low to the ground. If not, remove some of the "extra" wall material away from the bearing areas. There's a lot of weight there.
Unread 02-01-2008, 00:19
in between teams
AKA: Luke Van Oort
I wouldn't go so far as to say 'a lot of weight.' I can see this getting into the mid to high two pound range. That's, at most, a 1lb saving for the entire robot at the cost of significantly increase machining time. As drawn, the plates could be made on 195's EDM, if you add pocketing that significantly increases manufacturing time and adds another machine. (unless it is already being milled, then it just adds time)
If that middle plate can be eliminated though, that would save weight and make it easier to machine (one less part). I can't really see what that plate's purpose is so I don't know how easy that would be.
Unread 02-01-2008, 00:27
ADZDEBLICK's Avatar
The middle plate supports the shifting axle. If it were removed then that axle woudl have to be supported by the other 2 plates. When you shift, it would then hit the 70t gear.
We have both a cnc machine and an EDM, but some of the advisors were looking into using the AM Super Shifter this year to decrease machine time. When I designed this I had to keep this in mind and balance weight and machine time.
Unread 02-01-2008, 00:36
run the trap!!!
Team Role: Human Player
Why do people always say our [insert here] weighed [insert here] without motors? What good is a transmission without motors!
If I designed a drivetrain that only used two small CIMs and was able to push around all the multi-motor drivetrains in FIRST wouldn't that be a lot lighter and simpler than a drivetrain that used many motors?!
Sorry about getting us off topic. I actually think this is a pretty nice transmission - a crash shifting transmission looks simpler to build than a dog-shifting one. I wonder why more teams don't do it. Why did you choose crash-shifting over dog shifting?
-Philip J. Fry
Unread 02-01-2008, 00:41
ADZDEBLICK's Avatar
This transmission was meant to be an improvement on last years design which was smash shifting. I wanted to get something together before build so I went with what I had experience in.
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
It's Back! 4-Speed Shift-On-The-Fly Tranny. New and Improved! Travis Covington Robot Showcase 16 16-02-2005 18:28
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
